Transmission not holding when the car is not running, is this normal?
Old Apr 4, 2014 | 10:22 PM
BlackielawlessSS's Avatar
I have been drive standard shift vehicles since I was 16, v8's granted, and never have used the e brake. Ok so today, I went into a gas station I go to all the time, to grab a can of dip. It is a very minor slant. I have seen the car roll back maybe a foot. Today we were in there longer then normal, some guy comes in all frantic, whos black car is out front, I am about to leave. He asked me, and I say yes, he says its rolled back 4 feet to which it had. I didn't have the e brake up, because all of my other cars, including my 1.8T jetta never did it. I will use it on a big hill. Is this normal? It was in 1st gear. Non LSD trans if that helps. Is the trans getting weak?
Old Apr 4, 2014 | 10:29 PM
cfsnipers's Avatar
wouldn't that be an engine compression problem? or a slipping clutch.
Old Apr 4, 2014 | 10:35 PM
I wouldn't think so if it was not running, and was just sitting in gear. Thats a trans issue.
Old Apr 4, 2014 | 10:54 PM
And because the facebook responses say compression. This was the results when I ran them 3 weeks ago. I drive it normal, no more the 3k shifts. Its a daily. Here are the compression numbers. The clutch holds great. Will someone please explain this?
Cylinder 1=202
Cylinder 2=199
Cylinder 3=200
Cylinder 4=196
Old Apr 4, 2014 | 11:10 PM
heeter_33's Avatar
That's almost always poor compression but those numbers look decent.
Old Apr 4, 2014 | 11:15 PM
Car runs great now issues, no oil leaks, Still pulls like a boss. I have no worries with it.
Old Apr 5, 2014 | 12:32 AM
LNFTX's Avatar
My lnf will do it on a moderate incline if its in first and hot if its cold it wont budge but ive never had it move when I use reverse
Old Apr 5, 2014 | 04:44 AM
m33pm33p's Avatar
I've had mine roll 6 feet in front of my work on a slant. at 20k miles. Sooo just use your e brake?
Old Apr 5, 2014 | 06:30 AM
Mr.Tozzi's Avatar
What hilds the car when you have it in gear is the engine compression. And your clutch. Not the transmission. The only way you can blame your trans is if you leave it in 1st and come out with it in neutral.
Run a compression leakdown test. I would doubt its a clutch issue unless you're parked on a very steep hill.
vjoel2011
Oct 2, 2015 12:11 PM
ashalle2
Sep 16, 2015 10:36 PM
Jacque8080
Sep 9, 2015 09:21 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
