TWM Shifter orientation
I just installed my TWM Short Shifter this evening. I noticed that it seems leaned forward. 2nd is where the old neutral used to be. I thought i remember someone having this problem and there was an easy fix. If anyone could help me that would be great!
Thanks
Thanks
you just have to adjust your shift cables a bit and you'll be able to set it wherever you want to.
However, I recommend that you take your time doing this so that it sits well with each gear.
I saw how to go about adjusting the shift cables, but I think I may not exactly understand. I pulled out the metal U clip from the back of the main shift ball. I unsnapped the plastic white and grey cases to the shift cables, but it seems that regardless of where I set those it is still the same. Maybe i'm doing something wrong. I've looked at a couple of the threads here about shift cable adjustment but I can't seem to get a grasp of how it actually works.
Ok I think I got it. I seem to have gotten it adjusted a bit better. still leans forward which is actually pretty nice. But not quite as much as it had. Thanks for your help everyone.
Cptnslo
Sep 24, 2015 09:32 AM
