TWM Shifter orientation
Old Jan 4, 2007 | 11:35 PM
synapse82's Avatar
I just installed my TWM Short Shifter this evening. I noticed that it seems leaned forward. 2nd is where the old neutral used to be. I thought i remember someone having this problem and there was an easy fix. If anyone could help me that would be great!
Thanks
Old Jan 4, 2007 | 11:42 PM
SilverBalt's Avatar
tats the way the shifter sits, it is much moreforeward than the stock shifter, you get used to in after about a week
Old Jan 5, 2007 | 01:06 AM
tricky1's Avatar
yeah, my 2,4,R are where neutral used to be as well. I like it though.
Old Jan 5, 2007 | 01:30 AM
NGalaxyTimmyo's Avatar
you just have to adjust your shift cables a bit and you'll be able to set it wherever you want to.
However, I recommend that you take your time doing this so that it sits well with each gear.
Old Jan 5, 2007 | 01:35 AM
synapse82's Avatar
I saw how to go about adjusting the shift cables, but I think I may not exactly understand. I pulled out the metal U clip from the back of the main shift ball. I unsnapped the plastic white and grey cases to the shift cables, but it seems that regardless of where I set those it is still the same. Maybe i'm doing something wrong. I've looked at a couple of the threads here about shift cable adjustment but I can't seem to get a grasp of how it actually works.
Old Jan 5, 2007 | 01:53 AM
synapse82's Avatar
Ok I think I got it. I seem to have gotten it adjusted a bit better. still leans forward which is actually pretty nice. But not quite as much as it had. Thanks for your help everyone.
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
footballplaya3k
Sep 30, 2015 09:39 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
