zzp rear trans mount
So after about 2 hours I got my mount in, and first thing I noticed is when I started the car it sounded just a little different(louder) and holy hell idle vibrations..... After you get out of 1st it's ok, and then at about 80 on the highway it kinda comes back. Nor for just a simple single mount is this kinda vibs at idle normal? I figured it would shake a little, but nothing like it does..... Maybe a few days or so to break the mount in.
So I'll write up a sort of review based on what I've seen/felt with this mount so far.
First things first, yes it does bring a fair bit of vibrations up, but they will die down as the mount breaks in so to speak. Overall instalation was not bad, it does not take 2 people, but surely makes it easier. Powell has a good write up on the install of a mount.
now how about WHEEL HOP, ZZP has a 110% money back deal on these mounts if they don't get rid of WH. I still have a slight bit of hop at 7k in first gear, but for the most part the tires will just spin, and the car seems to shift a lot better into second, no more clunk from that old stock mount.
All in all for 100$ it was a good upgrade, but they should bundle the mounts into a kit for like 180ish and make it easier.
DANRICKARD
10-01-2015 12:08 AM
