ZZP stage 4 installed!
Old Mar 15, 2012 | 04:30 PM
T CUPP's Avatar
i just got my zzp stage 4 clutch installed along witht the upgraded throwout bearing. I was wondering what the break in period is?
Old Mar 15, 2012 | 04:49 PM
07LSJ's Avatar
i think i read once it was around 500 miles. in for info!
Old Mar 15, 2012 | 04:55 PM
user 72239's Avatar
Break in is usually 500 miles, city driving.
Old Mar 15, 2012 | 10:57 PM
bluebalt07's Avatar
I think 500 miles is the standard break in period for clutches should have a good bit of city driving so that you shift a good bit
Old Mar 15, 2012 | 11:05 PM
T CUPP's Avatar
okay the local shop that put it in somehow made my steering wheel not level. For example like when driving a straight line the steering wheel looks like im taking a slight turn. how do i fix this?
Old Mar 15, 2012 | 11:28 PM
CCrunner84's Avatar
Alignment most likely.
Old Mar 16, 2012 | 10:25 AM
bluebalt07's Avatar
Definitely alignment. And it's not that the shop screwed up, it's because the entire front suspension has to be removed (other than the struts) which makes it very likely that it won't be aligned when reassembled
Old Mar 16, 2012 | 10:27 AM
BLAZIN07SS's Avatar
I'm too JDM for you
subframe has to be removed on install so everything changes. it needs an alignment
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
