06 g85 ss/s259et
06 g85 ss/s259et
Still having some issues (Boost Creep, high IAT pulling timing due to an insufficient fan...) I will be going back on the Dyno when i install the HKS EVC.
Hoping to hit 400 on 19 lbs. Tq is way low..
379 hp 296 lb ft at 6845 RPM's 19 PSI on a Mustang Dyno.
The IAT were like 190 degrees around 6000 RPM's. I'm hoping with a better fan and the new boost controller I can keep it at a steady 19 lbs. The tuner added a good amount of fuel to make up for the creep!
Brand new Stock GM Crate LSJ
TTR IM
SMG ported Throttle body
ZZP s259ET Turbo Kit
MPx 3in Exhaust
80# mototron injectors
OTTP Return Style
Walbro 255lph GSS342
ZZP rewire
Bwoody Solid Mounts
FX 400 4 Puck
DriveShaftShop level 2
Hallman Pro Boost Controller
AEM Wideband
HP tuners
N2MB WOT Box
TTR IM
MPx 3in Exhaust
OTTP Return Style
ZZP rewire
Bwoody Solid Mounts
FX 400 4 Puck
AEM Wideband
HP tuners
N2MB WOT Box
WhineSSbaby
Sep 1, 2020 12:39 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
