Dyno Results Dyno pictures, videos and dyno results.
383_Stroker Returning To Dyno 11/23 -- Timing Experiments - Big Picts
Old Dec 1, 2010 | 08:37 PM
  #76
100% METH's Avatar
All preference I suppose
Thats rly good tho for e-85 considering what you've said about your tune
Old Dec 1, 2010 | 08:40 PM
  #77
WSFrazier's Avatar
Not taking credit for the tune, Bryan shared a lot of his findings with me... So I wouldn't have to find them myself. Saved me the hassle of a lot of dyno pulls and time
Old Dec 1, 2010 | 08:44 PM
  #78
100% METH's Avatar
I remember him saying something about raising stoich about 7% to compensate.
right on... he definitely lives up to his reputation
Old Dec 1, 2010 | 09:05 PM
  #79
383_Stroker's Avatar
He likes to run a 10.4 stoich point for e-85 instead of a 9.7.. its a good compromise between e85 and e70
Old Dec 1, 2010 | 09:06 PM
  #80
100% METH's Avatar
e-85 needs to become more plentiful out this way
Old Dec 2, 2010 | 12:05 AM
  #81
InfraRedline's Avatar
I know adding some timing in the cruising range will help mileage a bit. I was going to do it all fall and never did lol! Still get 21mpg in town though when its fairly warm, so hopefully adding some timing will get me even better mileage.
I just thought it was funny how close the tables were at WOT
Old Dec 2, 2010 | 01:36 PM
  #82
Area47's Avatar
Rent me! per hour
the 10.4 is to keep the ltft's at bay. ethanol content changes daily. a 5% swing in either direction won't make or break it.
steve, reputation being?
Old Dec 2, 2010 | 02:28 PM
  #83
100% METH's Avatar
An experienced tuner in general
You already know your a hard ass
Old Dec 2, 2010 | 04:34 PM
  #84
WSFrazier's Avatar
easy
Old Dec 2, 2010 | 07:35 PM
  #85
Originally Posted by WSFrazier
easy
Like a hotdog down a hallway....
Old Dec 2, 2010 | 09:43 PM
  #86
Area47's Avatar
Rent me! per hour
easy
this is true. you also have a mouth like a hoover
Old Dec 8, 2010 | 11:06 AM
  #87
SuperSport4's Avatar
Let me try to comprehend some things here based off some hints or "puzzle pieces" you have left in multiple threads lol.
You always say people dont run lean enough to take advantage of over 25.5*, but if I am correct (again this is me trying to figure you out) you like to run E85 at 11.5 tapering to 11.8 AFR since you said you have found over 11.8 is losing power on E, which is similar to what he is running. So do you not go past that much timing as well?
Which leads me to believe that maybe when you were on race gas or meth that you leaned the car out more and pumped more timing into it.
Am I close? Or maybe way off
... i dont understand this at all.... how can you run leaner and up the timing?? wouldent that give you knock??? i run about 12.0 afr and about 25* timing.... so what you are saying is lean it out even more and add more timing... sounds like a recipe for disaster.... please enlighten me if you will
Old Dec 8, 2010 | 12:08 PM
  #88
What I was getting at is that I assumed he was on race gas when he was pushing the timing really hard and leaning it out and still making power. Its like E85 where you have to try pretty damn hard to get it to knock, except on E85 he found that leaning it out actually lost power. If you try really leaning the car on pump gas or many meth mixes you will start knocking pretty quickly.
Old Dec 8, 2010 | 12:26 PM
  #89
x2
Old Apr 13, 2012 | 10:50 AM
  #90
I Can't edit this original post anymore for some reason.. but.. I will quote and fix the links in this post.
Originally Posted by 383_Stroker
So, I'm moving in 3 weeks.. That means I need (lol) to get back on the dyno here before i go... Who needs to save money for a move when they have tuning software and a local dyno?
I plan on trying several timing curves and a flat AFR versus a lean to rich..
The ones below are what i plan to try.. Which one do you think will be make the most power? (Or do we think they are all going to be the same?)
Open for suggestions as well
Current Timing:
Pull 2:
Pull 3:
Pull 4:
Pull 5:
Old Apr 13, 2012 | 11:11 AM
  #91
Results
When I speak AFR in this post, that's gasoline equivalent, not actual
Current Timing:
This pull was wacked out and the car made like 100hp to 5000 rpm and then jumped up.. and i was anxious to move on so we didn't repull it
Pull 2 and 2a:
Red Line is a 13.0 falling to a 12.0 at redline
Blue Line is a flat 11.8
Pull 3:
Flat Fueling gave me the same result on the next two pulls so i stuck with it after that point and am only going to show the graphs for flat 11.8 from here on
Blue Line is the better run two
Red Line is the timing table above
Pull 4:
Same two runs as above + Green Line is the timing table above
Then i took ebristols suggestion:
Previous green line is the original pull 4 timing table, the blue is ebristol's suggestion (and the highest of the day)
Pull 5:
Blue line is the ebristol suggestion from above
And finally a chart showing where i started the day versus where i finished Pull 2 versus Pull 4b
Soooo, based on my experience today.. cramming as much timing in as you can, as early as you can and holding it is the way to go.. .. thats pretty common sense
Old Apr 13, 2012 | 11:13 AM
  #92
Added Bonus: 3rd Gear vs 4th gear pull
Red is 4th if i remember correctly..lol
Old Apr 13, 2012 | 11:30 AM
  #93
1AJeremyD's Avatar
Thanks for updating the thread with the old graphs! I'm trying to get into tuning a bit more now with my friend Gremlin85 being a decent guide but stuff like this definitely helps me understand the engine a bit more.
Old Apr 13, 2012 | 11:31 AM
  #94
turbo86's Avatar
So 325hp / 270trq
very nice 383! So in a speed contest with your friend who has the tuned TC, how does it do.
Old Apr 13, 2012 | 12:12 PM
  #95
Originally Posted by turbo86
So 325hp / 270trq
Those are the numbers from December 2010, my image site moved, so i had to update the thread to get the images back in it. I've still not dynoed on the new set-up.
Before the ported head and springs, I could slowly pull my tuned tc friend .. We've not raced since then.
Old Apr 13, 2012 | 04:50 PM
  #96
RooTBeeR's Avatar
R&D is good
Old Apr 13, 2012 | 05:51 PM
  #97
turbo86's Avatar
^ AGREED
very cool Stroker... you should def. get another dyno run in and see what it is doing now...
Old Apr 13, 2012 | 07:05 PM
  #98
100% METH's Avatar
I hear if you advance timing to 64 degrees @ peak torque fun things happen
Old Apr 13, 2012 | 11:55 PM
  #99
Area47's Avatar
Rent me! per hour
it's ****** magic i tell ya
Old Oct 27, 2012 | 12:07 AM
  #100
Omnigear's Avatar
warp cat agree
