Dyno Results Dyno pictures, videos and dyno results.
Dynotech TVS Dyno
Old Mar 9, 2012 | 12:36 AM
InfraRedline's Avatar
Dynotech TVS Dyno
Finally got on the Dyno Dynamics Dynotech today. I put the 2.9 back on for some baseline runs and dialed in the AFR to a mid to high 11 ramp. Got it on the dyno and it was in the LOW 10's so I had him cut it off early and I leaned it back out. Had a few issues losing tach signal but they got it figured out and the car put down 326whp and 240wtq. I made a few more pulls with similar to slightly lower resutls as the temps started climing after 10 pulls (yes 10 lol).
I then swapped to the 2.7 and got the AFR back to the same as it was on the 2.9. IAT2 started at 118* on this pulley as opposed to around 100* on the 2.9 because it just wouldnt drop even with the fans on it and rolling in 3rd gear. Temps reached 163* by the end of the run and the car started pulling timing a bit which resulted in 328whp and 252wtq, with about a 12-15whp throughout the powerband.
Heres the graph
Keep in mind this is on a dyno dynamics dynotech.
Going to get the temps under control and fix a few things and see where its at.
Pic of the car on the dyno
Ill post vids when I get them off my camera!
Old Mar 9, 2012 | 03:25 AM
100% METH's Avatar
Post the graph showing rpm foolio
Old Mar 9, 2012 | 04:25 AM
Frogstofall's Avatar
Nice! In for vids...
Old Mar 9, 2012 | 07:31 AM
Staged07SS's Avatar
Administrator
Administrator
Hey man, post this in the dyno thread, and I will add your new numbers. Thanks!
Old Mar 9, 2012 | 09:32 AM
383_Stroker's Avatar
Well, doing a quick google search, it seems a dyno dynamics dyno reads between 10-18% lower than a dyno jet. (Several threads on various forums where people supposedly did them back to back).
So based on that.. Hella good numbers sir.
Old Mar 9, 2012 | 09:39 AM
BlackMagic's Avatar
Originally Posted by 383_Stroker
Well, doing a quick google search, it seems a dyno dynamics dyno reads between 12-18% lower than a dyno jet. (Several threads on various forums where people supposedly did them back to back).
X2.. I also looked this up, looks like using the minimum 12% lower reading, he would have been just about right at 370whp and thats on the lower end.
Old Mar 9, 2012 | 12:18 PM
Thanks guys! I was kind of bummed even though I knew that DD dyno's tend to run a little on the low side lol was expecting a little low but its just different when you actually see the numbers. Either way, im happy with the shape of the power curves.
Staged ill get the vids together and post mine and my friend's TC in there! We got his car to 401whp and 375wtq on 23psi and E47 on the pte5557, but we were running out of fuel in the mid range.
Old Mar 9, 2012 | 12:21 PM
Staged07SS's Avatar
Administrator
Administrator
Nice!!! Sounds good thanks
Yeah, your torque curve is nice and flat. The power curve looks nice to.
Old Mar 16, 2012 | 10:58 PM
Bluelightning's Avatar
Got Bewst?
Wicked numbers considering man. Didn't you trap like 116mph at the track iirc?
Old Mar 19, 2012 | 11:55 PM
Sorry I still havent posted the vids. Just got back from Montana the other day.
Found out I was getting belt slip on the 2.7 so I put on a 3" tensioner pulley and fixed that issue. Yes I was trapping 116mph on the 2.7 with a little belt slip above 6k rpms and 26" tall tires.
SmitBag
Sep 7, 2016 08:05 AM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
