Dyno Results Dyno pictures, videos and dyno results.
first tvs dyno...363whp
Old Sep 15, 2013 | 10:13 PM
robertmichaels's Avatar
Had an opportunity to dyno my TVS.
note this is a base tune with the maf turned off
Tvs
2.9
Ati oversized
Zzp 3" intake
Zzp long tube header and hi flow cat
Zzp stage 2 cams
Zzp neutral balance shafts
Mr.B hardened timing guide bolts
Id1000cc injectors
Ottp return style with aem e85 pump
E85
7250 rev limit
82# valve springs and Ti retainers
http://i897.photobucket.com/albums/a...ps3ab5d042.jpg
Old Sep 15, 2013 | 10:33 PM
JapEatr's Avatar
South Central *********
Good numbers for that size pulley
Old Sep 15, 2013 | 10:40 PM
100% METH's Avatar
Nice torque curve too
Dyno shop have a bad pickup? or you getting knock/blow out?
Old Sep 15, 2013 | 10:43 PM
Powell Race Parts's Avatar
lol haha
2.9 is fine
Old Sep 15, 2013 | 10:49 PM
100% METH's Avatar
Lol... LET IT GO POWELL!!!
Old Sep 15, 2013 | 11:14 PM
u got to let it go lol
Old Sep 15, 2013 | 11:16 PM
EXsoccer1921's Avatar
lol haha
2.9 is fine
Old Sep 15, 2013 | 11:23 PM
Way to much fuel for the lower mid range...we are still tuning
Old Sep 15, 2013 | 11:30 PM
Noticed you have cams and springs, did you do any porting?
Old Sep 16, 2013 | 08:58 AM
Did a very mild exhaust port but not flow matched, just cleaned them up
Old Sep 16, 2013 | 09:03 AM
Staged07SS's Avatar
Administrator
Administrator
Curious why you arent reving out further?
You have the supporting mods to do so.
Old Sep 16, 2013 | 09:11 AM
JapEatr's Avatar
Fuel...
Old Sep 16, 2013 | 09:15 AM
574's Avatar
574
Nice set up. Good numbers. Be nice to that stock block
Old Sep 16, 2013 | 09:16 AM
574's Avatar
574
Fuel...
With 1000's? I think he should be able to go a bit further.. I was only revving to 7k when I had the 2.6 on my 1000's and there was some room on the table still
Old Sep 16, 2013 | 09:23 AM
Staged07SS's Avatar
Administrator
Administrator
Fuel...
With a 2.9?
Old Sep 16, 2013 | 09:29 AM
I dont want to blow my motor, I could easily rev to 7500 you can see from the graph my cams were still making power..and im only hitting 76% idc
Old Sep 16, 2013 | 09:33 AM
I dont like how fast my iat2 rises..went to the drag strip when it was 100 out, sitting on the line they were 150 by the end of the quarter I saw 200 and by the time I pulled off they fell down to 130
Old Sep 16, 2013 | 09:49 AM
Staged07SS's Avatar
Administrator
Administrator
Easy solution.... Don't go to the strip in 100 degree temps
Rev her out and take full advantage of those supporting mods (ati, cams, & springs).
Nice numbers though.
Old Sep 16, 2013 | 09:53 AM
yellowsupercharged06's Avatar
rev that bitch out lol .... nice numbers too
just another reason to not go tubo !!!
Old Sep 16, 2013 | 01:37 PM
100% METH's Avatar
Water injection will keep the iat2 from hitting 200*
Specifically a 10-12gph 50/50 for use with the 2.9 Tvs pulley.
Spraying pre blower will substantially reduce blower discharge temps and maintain an over all higher efficiency as boost increases.
Old Sep 16, 2013 | 01:52 PM
army_greywolf's Avatar
Read first post again, MAF is OFF, I cannot overshoot the VE table, therefore you can't push the revs. Make sense now? Rob knows he can't keep going beyond that until we set MAF up for a 5800 takeover, there is too much turbulance in the intake stream to run the car on MAF down low.
Old Sep 16, 2013 | 02:22 PM
Tennpenn83's Avatar
Sub'd. Good numbers.
Old Sep 16, 2013 | 02:38 PM
advise's Avatar
Nice
Should be dynoing this week
Hope I make it up there
Old Sep 16, 2013 | 02:46 PM
JapEatr's Avatar
Fuel pump dont care... The dw300 cant keep up past 7400
Old Sep 16, 2013 | 02:50 PM
advise's Avatar
I have no issue with fueling over 7400
