How to estimate max wtq from 60-100 time
if your using that 8.2 sec 60-100 from a magazine or something you have to remember there was a shift in that pull. so it would actually be a little faster making about 240
and sundevil i would expect about 328 from a catless dp and 20 psi tune. it was prob hot as hell when u did it too
There's a virtual dyno that the WRX/EVO guys use by a gentleman named Brian. Supposed to be pretty accurate and is currently being configured for a multitude of cars.
Do a google search and it will do all of the math listed on the first post for you.
my car does mid to high 3s it is hard to get a correct time when i am spinning a little all the way through 3rd i will get a good log once i get my new tire but here is my dyno graph 06 ss/sc turbo swap
I have actual dyno data to compare, but if I calculate using what the thread starter stated, my calculated torque is a little low compared to actual measured torque. Now, if I use 80% instead of 85% to figure peak (last step), then it is dead on.
