Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread
Old 03-03-2010, 11:24 AM
  #151
ebristol's Avatar
Originally Posted by Tennpenn83
damn that is a flat torque curve
Its because of the graph scaling. Notice HP max is set at 400 and TQ is set at 300. So it looks different then most other charts you will see.
ebristol is offline
Old 03-03-2010, 11:38 AM
  #152
Tennpenn83's Avatar
yeah, i noticed that. lines don't cross at 5252. but that doesn't change how flat the torque curve is.
Tennpenn83 is offline
Old 03-03-2010, 11:55 AM
  #153
ebristol's Avatar
Oh really?
Which TQ curve is flatter?
Run 6 from this Graph? OR
The correction Factor is different but they are the same run. Just different chart scaling.
I already through this with Xavier in the past...
ebristol is offline
Old 03-03-2010, 12:50 PM
  #154
Darkmanx's Avatar
Yeah correction will change the way the graph look. but bOTh your graphs are shakey. mine looks the same just at different angles. heres tenn i think this is a run from earlier that day tenn i think this is what u wanted to see . i used a different correction
Darkmanx is offline
Old 03-03-2010, 05:55 PM
  #155
Tennpenn83's Avatar
i think EB is misinterpreting what i said. i know about correction factors and whatnot. i was just commenting on the flat torque curve, which flat-ness would not change on correction factor. actual numbers displayed might change, but the curve itself would not.
Old 03-05-2010, 04:08 PM
  #156
skatin_boarding's Avatar
Heres my numbers 279/258. I/DP/T/80#/2.7/HE/M62/E85
and the graph...
skatin_boarding is offline
Old 03-05-2010, 05:11 PM
  #157
ebristol's Avatar
Originally Posted by skatin_boarding
Heres my numbers 279/258. I/DP/HPT/80#/2.7/HE/M62/E85
E-85 Strikes again!
ebristol is offline
Old 03-05-2010, 05:22 PM
  #158
EXsoccer1921's Avatar
yeah but whats the correction factor?? i would hate to drive your car if that is corrected and smoothed. hahah
seems like the tune could use some work too. constructive critizism mind you. but with a 2.8/60s and 91 i was putting down 273/250
Last edited by EXsoccer1921; 03-05-2010 at 05:22 PM. Reason: Automerged Doublepost
EXsoccer1921 is offline
Old 03-05-2010, 05:28 PM
  #159
ebristol's Avatar
He posted this in a different thread. Here is one of his good graphs.
Originally Posted by skatinboarding
Well I got about 5 pulls in and my best was 279.5/258. Its about what I was expecting with my stock header and catback. Their rpm tack wasn't getting a good signal so all of them look shaky. All were 11.5 afr with 25* of timing. E-85 with a 2.7" pulley.
I would say the tune looks pretty good to me.
ebristol is offline
Old 03-05-2010, 05:34 PM
  #160
why didn't he post that one?
i guess i over looked that he is on the stock header and catback as well. not so bad now
Last edited by EXsoccer1921; 03-05-2010 at 05:34 PM. Reason: Automerged Doublepost
Old 03-05-2010, 05:48 PM
  #161
Yeah their rpm tack wasn't getting a good signal. I posted the shaky one cause it had the best number.
Old 03-05-2010, 06:04 PM
  #162
well i'm sure you already know what you need to do lol. but get you a real heat exchanger, header and catback, and some more cooling and you'll be high 280s if not 90s
Old 03-05-2010, 07:03 PM
  #163
I know. Its nice to have a good base dyno to see my gains from the exhaust. Dual pass is coming up with opt b. We will see what my temps are after that and maybe a new h/e. Im thinking of swaping turbo soon. Its amazing what e85 does!
Old 03-06-2010, 02:34 AM
  #164
ralliartist's Avatar
updated! Congrats skatin boarding, that's good enough for the #8 spot on the ole M62!
ralliartist is offline
Old 03-15-2010, 07:16 PM
  #165
Darkmanx's Avatar
Darkmanx is offline
Old 03-16-2010, 05:09 AM
  #166
will update tonight when I get home from work.
Old 03-16-2010, 01:25 PM
  #167
What's your full mod list Darkmanx?
Old 03-23-2010, 12:08 PM
  #168
Maxim_X's Avatar
Thanks for the quick update rally!
Maxim_X is offline
Old 03-23-2010, 12:53 PM
  #169
no problem
Old 03-23-2010, 01:10 PM
  #170
BYT*SS*TURBO's Avatar
I can haz update?
09 SS/TC
ZZP Catless DP, Injen CP, Hahn CAI, HKS EBC, HP Tuned @ 22psi
Should have a 25psi dyno very soon with hopefully something in the ~340whp area
BYT*SS*TURBO is offline
Old 03-23-2010, 01:15 PM
  #171
wantedSS/TC's Avatar
^^ wish I was there. I can haz 315whp+ shortly?!
wantedSS/TC is offline
Old 03-23-2010, 01:17 PM
  #172
Get to work on that bitch and head up to my place this weekend
Old 03-23-2010, 01:20 PM
  #173
^ roger that ...
Old 03-23-2010, 01:54 PM
  #174
updated
  #175
Thanks sir
Quick Reply: The Official Dyno Thread
