Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread 2015
Old 09-12-2017, 12:40 PM
  #526
Administrator
Administrator
Staged07SS's Avatar
I will get this updated this week!
Old 09-26-2017, 11:54 AM
  #527
Viperoni's Avatar
Originally Posted by Shanman
Gotcha figured it out
1st run no exhaust
2nd run exhaust
3rd run icebox
For the 1st run no exhaust / 2nd run with exhaust - where did you disconnect the exhaust at?
Old 10-19-2017, 12:24 PM
  #528
Administrator
Administrator
Staged07SS's Avatar
I didn't forget about updating this.... I've been super busy at work. I usually only have a min or two at best to check in a few times a week lately. I will get everything up to date eventually!!
Old 10-29-2017, 08:45 AM
  #529
zeeky420's Avatar
2010 cobalt ss
Zzp hot/cold charge pipes
3 bar maps
Zzp catless downpipe
BW 257exe turbo
Zzp FMIC
hahn Cat back exhaust
E47 fuel tuned on 26psi
opel injectors
LT4 high pressure fuel pump
kmo tuned
F40 6 speed transmission swap
Old 12-07-2017, 02:33 PM
  #530
armcclure's Avatar
Jeff you still here?
Old 12-07-2017, 04:18 PM
  #531
Al, youre still here?
Old 12-07-2017, 07:59 PM
  #532
armcclure's Avatar
apparently so. Was bored out of my mind.
Old 12-08-2017, 10:17 AM
  #533
You must need a new job...
Old 12-08-2017, 10:48 AM
  #534
armcclure's Avatar
LOL that's exactly the problem. I don't start there till Jan. And there's nothing to do here.
Old 03-12-2018, 09:46 AM
  #535
armcclure's Avatar
The fk jeff. We need updates.
Old 09-18-2018, 11:06 AM
  #536
Slobodan Milošević
07blackg5's Avatar
They accidentally plotted the same run twice
Old 09-18-2018, 12:34 PM
  #537
jdbaugh1's Avatar
You wouldn't happen to have the graph vs. engine rpm instead of speed would you?
Old 09-18-2018, 12:58 PM
  #538
Slobodan Milošević
07blackg5's Avatar
intersection is 5252 and peak is 8100
Old 09-18-2018, 01:04 PM
  #539
jdbaugh1's Avatar
So did you start your pull at around 4,800-5,000 rpm?
Old 09-18-2018, 01:13 PM
  #540
Slobodan Milošević
07blackg5's Avatar
this one we started high, yes
Old 09-18-2018, 01:16 PM
  #541
jdbaugh1's Avatar
Do you have any idea how they configured the loading for this run?
Old 09-18-2018, 01:17 PM
  #542
Slobodan Milošević
07blackg5's Avatar
no
Old 09-18-2018, 01:55 PM
  #543
Slobodan Milošević
07blackg5's Avatar
of course. e85 is life
Old 09-18-2018, 03:01 PM
  #544
Originally Posted by HGT
How were they picking that up that it was so high at first? Tip of the tail pipe?
Yeah the dyno sensor is just a rig that holds a wideband in the tail pipe so not the most accurate.
Old 11-05-2018, 05:11 PM
  #545
armcclure's Avatar
road simulation
Old 01-19-2019, 08:36 PM
  #546
Andrew Hoover's Avatar
Dyno Graph
My Lsj-T stock motor. 80s, e85, s257
Old 01-20-2019, 10:42 PM
  #547
96S1's Avatar
Andrew, there's no attachment.
Staged07SS
10-25-2013 07:33 PM
BYT*SS*TURBO
02-21-2012 01:02 PM
ralliartist
12-30-2011 11:39 PM
ralliartist
05-19-2011 02:34 AM
Khase
03-30-2011 11:10 PM
Quick Reply: The Official Dyno Thread 2015
