Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread 2015
Old Sep 12, 2017 | 12:40 PM
  #526
Staged07SS's Avatar
Administrator
Administrator
I will get this updated this week!
Old Sep 26, 2017 | 11:54 AM
  #527
Viperoni's Avatar
Originally Posted by Shanman
Gotcha figured it out
1st run no exhaust
2nd run exhaust
3rd run icebox
For the 1st run no exhaust / 2nd run with exhaust - where did you disconnect the exhaust at?
Old Oct 19, 2017 | 12:24 PM
  #528
Staged07SS's Avatar
Administrator
Administrator
I didn't forget about updating this.... I've been super busy at work. I usually only have a min or two at best to check in a few times a week lately. I will get everything up to date eventually!!
Old Oct 29, 2017 | 08:45 AM
  #529
zeeky420's Avatar
2010 cobalt ss
Zzp hot/cold charge pipes
3 bar maps
Zzp catless downpipe
BW 257exe turbo
Zzp FMIC
hahn Cat back exhaust
E47 fuel tuned on 26psi
opel injectors
LT4 high pressure fuel pump
kmo tuned
F40 6 speed transmission swap
Old Dec 7, 2017 | 02:33 PM
  #530
armcclure's Avatar
Jeff you still here?
Old Dec 7, 2017 | 04:18 PM
  #531
Al, youre still here?
Old Dec 7, 2017 | 07:59 PM
  #532
armcclure's Avatar
apparently so. Was bored out of my mind.
Old Dec 8, 2017 | 10:17 AM
  #533
You must need a new job...
Old Dec 8, 2017 | 10:48 AM
  #534
armcclure's Avatar
LOL that's exactly the problem. I don't start there till Jan. And there's nothing to do here.
Old Mar 12, 2018 | 09:46 AM
  #535
armcclure's Avatar
The fk jeff. We need updates.
Old Sep 18, 2018 | 11:06 AM
  #536
07blackg5's Avatar
Slobodan Milošević
They accidentally plotted the same run twice
Old Sep 18, 2018 | 12:34 PM
  #537
jdbaugh1's Avatar
You wouldn't happen to have the graph vs. engine rpm instead of speed would you?
Old Sep 18, 2018 | 12:58 PM
  #538
07blackg5's Avatar
Slobodan Milošević
intersection is 5252 and peak is 8100
Old Sep 18, 2018 | 01:04 PM
  #539
jdbaugh1's Avatar
So did you start your pull at around 4,800-5,000 rpm?
Old Sep 18, 2018 | 01:13 PM
  #540
07blackg5's Avatar
Slobodan Milošević
this one we started high, yes
Old Sep 18, 2018 | 01:16 PM
  #541
jdbaugh1's Avatar
Do you have any idea how they configured the loading for this run?
Old Sep 18, 2018 | 01:17 PM
  #542
07blackg5's Avatar
Slobodan Milošević
no
Old Sep 18, 2018 | 01:55 PM
  #543
07blackg5's Avatar
Slobodan Milošević
of course. e85 is life
Old Sep 18, 2018 | 03:01 PM
  #544
Originally Posted by HGT
How were they picking that up that it was so high at first? Tip of the tail pipe?
Yeah the dyno sensor is just a rig that holds a wideband in the tail pipe so not the most accurate.
Old Nov 5, 2018 | 05:11 PM
  #545
armcclure's Avatar
road simulation
Old Jan 19, 2019 | 08:36 PM
  #546
Andrew Hoover's Avatar
Dyno Graph
My Lsj-T stock motor. 80s, e85, s257
Old Jan 20, 2019 | 10:42 PM
  #547
96S1's Avatar
Andrew, there's no attachment.
Old Nov 4, 2025 | 11:20 AM
  #548
tomj77's Avatar
2.0 LSJ Supercharged - M62 Power
1. Tstone, 315whp, 282wtq, Verified Dynojet, 2.6/80s/I/H/DP/E/TB/PH/C/VS/FI/PI/T/E85, Graph
2. kcc140, 310whp, 272wtq, Verified Dynojet, 2.6/80s/I/H/DP/E/T/HE/PH/PB/E85, Graph
3. armcclure, 309whp, 270wtq, Verified Dynojet, 2.5/98s/F/H/DP/E/T/SP/RS/WI/PB/CD/TB/PH/C/VS/E85/FS, Graph
4. Hockeyman, 309whp, 269wtq, Verified Dynojet, 2.7/80s/ATI/I/H/DP/E/T/DU/HE/PH/IM/C/VS/E85, Graph
5. ebristol, 303whp, 273wtq, Verified DynoJet, 2.6/80s/F/H/DP/CD/E/T/DU/HE/E85, Graph
6. riceburner, 302whp, 271wtq, Verified Dynojet, 2.7/80s/ATI/I/H/DP/E/T/DU/WI/PB/HE/PH/IM/C/VS/E85/BS, Graph
7. Jfettig, 294whp, 272wtq, Verified Dynocom, 2.7/80s/I/F/H/DP/TB/T/E85, Graph
8. InfraRedline, 294whp, 249wtq, Verified Dynocom, 2.7/80's/I/H/DP/PH/C/VS/E85, Graph
9. stealthy1ss, 291whp/248wtq, Verified Mustang Dyno, 2.9/80s/H/DP/CD/CO/HE/AB/E85/T, Graph
10. ncstateredline, 289whp, 262wtq, Verified Dynojet, 2.8/80s/I/H/DP/HE/E85/T, Graph
11. CobaltSS16, 288whp, 250wtq, Verified Dynojet, 2.7/80s/I/H/DP/CD/E/HE/E85/PB/T, Graph
12. ROADKONE, 285whp, 244wtq, Verified Dynomite, M62/2.8/60s/I/H/DP/CD/T/DU/HE/OPTB, Graph
13. jamies06ss/sc, 284whp, 249wtq, Verified Mustang Dyno, 2.8/80s/HE/I/DP/T/GMHP/E/OPTB/DU/E85, Graph
14. skatin boarding, 279whp, 258wtq, Verified Dyno, 2.7/80s/I/DP/T/HE/E85, Graph
15. smthomas556, 279whp, 247wtq, Verified Dynojet, 2.7/80s/I/H/DP/CD/E/HE/CM/T/E85, Graph
16. BoostedYards86, 276whp 248wtq, Verified DynoJet, 2.7/60s/I/H/DP/CD/E/HE/DU/T/TB/WI, Graph
17. startingline05, 274whp, 252wtq, Verifed, 2.6/60s/I/H/DP/E/WI/HE/PB, Graph
18. OntarioKev, 273whp,267wtq, Verified Dynojet, 2.7/60s/WI/I/H/DP/E/HE/DU/T, Graph
19. zfissette, 273whp, 262wtq, Verified Dynojet, Graph
20. Area47, 273whp, 254wtq, Verified Dynojet, 2.8/42s/I/H/DP/E/WI, Graph
21. EXsoccer1921, 273whp, 249wtq, Verified Dynojet, 2.8/60s/I/H/DP/E/T/WI/HE, Graph
22. Shaneman, 272whp, 232wtq, Verified Dynojet, 2.9/60s/I/H/E/DP/T/CD/HE/TB/PH/C/PI/BS/FI/OPTB/VS, Graph
23. jamespe42038, 271whp, 248wtq, Verified Dynojet, 2.9/h/dp/am/t, Graph
24. HONKY BOY, 270whp, 257wtq, Verified Dyna Pack, 2.8/60s/AM/H/DP/E/DU/HE/T, Graph
25. crazywhiteboy89, 270whp, 242wtq, Verified Dynojet, 2.7/I/H/CD/DP/E/T/HE/CM/DU, Graph
26. Gixxerboy02, 265whp 255wtq, Verified Dynojet, 2.7/65s/H/E/I/DP/DU/CD/WI/T, Graph
27. INFE, 264whp, 246wtq, Verified, 2.8/60s/I/H/E/T, Graph
28. Cobalttc05, 264whp, 232wtq, Verified, 2.9/42s/I/H/DP/E/T/HE, Graph
29. tityrous, 263whp, 201wtq, Verified Dynojet, 3.35/60s/I/DP/E/T/DU/RS/PB/HE/TB/PH/C/FI/OB, Graph
30. MSHETZ, 262whp, 241wtq, Verified Dynojet, 2.7/60s/H/DP/E/HE/I/T, Graph
31. poundz9oh9, 262whp, Verified Mustang 2.7/60s/HE/CAI/DU/H/DP/T, Graph
32. recklessactn, 261whp 228wtq, Verified Mustang Dyno, 2.9/42s/I/H/DP/T, Graph
33. yellow dragon, 260whp, 251wtq, Verified Dynojet, 2.6/60'S/T/WI/DP/OPT B/CD/DU/HE/H/M62/RG(94OCT)/F/I, Graph
34. stage2, 260whp 241wtq, Verified, I/H/DP/GM2, Graph
35. Micro, 260whp, 238wtq, Verified DynoDynamics, 3.0/42s/F/AM/GMH/DP/DU/HE/GM3, Graph
36. Evoly, 260whp, 226wtq, Verified mustang, 3.07/I/H/E/GM2, Graph
37. spchrgd, 259whp, 234wtq, Verified Dynojet, 2.8/50s/I/HE/T, Graph
38. ColeJJones, 258whp, 235wtq, Verified Dynojet H, DP, E, WI, DU, HE, 2.7, 60s, PB, Graph
39. Bluelightning, 258whp, 226wtq, Verified 2.8/60s/AM/WI/HE/DU/T, Graph
40. BriantheLion26, 256whp, 242wtq, Verified Dynojet, 2.8/60s/I/DP/E/T/WI/HE, Graph
41. UlWizSS - 253whp, 223wtq, Verified Dynojet, 2.9/DP/I/GM3, Graph
42. Bl4des 250whp, 238wtq, Verified Dynojet, 2.7/60s/I/H/E/T/DU/HE, Graph
43. BlackJackSS, 248whp, 222wtq, Verified Dynojet, 2.8/42s/I/E, Graph
44. DVSk8er, 245whp, 221wtq, Verified Mustang, 2.8/60s/I/E/WI/T, Graph
45. jonathan923, 243whp, Verified Dynojet, I/DU/HE/PB, Graph
46. jvirginillo, 242whp, 228wtq, Verified Dynojet, 2.8/60s/I/H/DP/E/HE/T, Graph
47. RBC 241whp, 222wtq, Verified Dynojet, I/E/HE/GM2, Graph
48. Unforgi3n, 241whp, 218wtq, Verified Dynojet, I/DP/CM/GM2, Graph
49. spitefulxcheerio, 241whp, 211wtq, Verified Dynojet, I/GM2, Graph
50. D Rob, 225whp, 195wtq, Dynojet Dyno, STOCK, Graph
51. yellow dragon, 216whp, 187wtq, Verified WinDyn, AM, Graph,Chart1,Chart2
2.0 LSJ Supercharged - All Out POWER POTENTIAL (TVS1320, TVS1900, Twinscrew, MP90, H62, Centrifugal Blower, Nitrous)
1. 100%METH, 424whp, 291wtq, Verified Dynojet, TVS1320|2.8|i|tb|h|cd|e|t|he|vs|ph|C(ZZP STG 3)|CR 11:1|e85|fs|fprw|rs|1200cc fic inj|bs , Graph
2. TStone, 418whp, 335wtq, Verified Dynojet, M62/2.9/80s/I/H/DP/E/T/TB/PH/C/E85/FI/PI/N20[100], Graph
3. mrbelvedere, 401whp, 314wtq, Verified Dynojet, TVS1320/2.8/160s/I/F/C/ATI/RS/E85/FI/T/PH/H/CD/E/N20[50], Graph
4. Coreyallan, 396whp, 305wtq, Verified Dynomite, TVS1320/2.6/100s/E85/I/F/DP/E/T/CD/FS/PH/C/TB, Graph
5. Shanman, 391whp, 301wtq, Verified Dynojet, TVS1320/2.7/1000cc/E85/I/H/E/DP/T/CD/HE/TB/PH/C/PI/BS/FI/OPTB/VS, Graph
6. freakta, 389whp, 322wtq, Verified Dynojet, TVS1320/2.5/60s/I/H/DP/E/RS/TB/PH/C/VS/IM/IC/FI/PI/OB/RG/T/STR, Graph
7. JapEatr, 383whp, 291wtq, Verified Dynojet, TVS1320/2.6/ATI/I/H/DP/CD/E/T/E-85/PI/TB/1000s/DU/PD/RS/FS/C/FI, Graph
8. riceburner, 380whp, 283wtq, Verified Dynojet, TVS1320/2.8/98s/RSFS/FPRW/E85/ATI/BS/PH/C/TB/I/H/DP/E/T/VS/OPTB/DU/HE, Graph
9. Advise, 376whp, 286wtq, Verified Dynojet, TVS1320/2.7/98s/I/H/DP/E/T/DU/HE/RS/CD/C/PH/FS/E85, Graph
10. Area47, 374whp, 315wtq, Verified Dynojet, TVS1320/2.5/98s/I/H/DP/CD/E/E-85/T/PH/VS/RS, Graph
11. CBodnar, 373whp, 363wtq, Verified Dynojet, 2.8/60's/HE/DU/H/DP/I/T/N20[125], Graph
12. InfraRedline, 370whp, 292wtq, TVS1320/2.6/I/H/DP/E/98#/PH/C/RS/DU/T/E85, Graph
13. Darkmanx, 364whp, 303wtq, Verified Dynojet, TVS1320/2.8/PH/DU/CM/HE/E/I/H/DP/CD/E85/T, Graph
14. ThexGovenor, 358whp, 284wtq, Verified Mustang Dyno, TVS1320/2.7/80s/I/E/H/DU/T/RS/HE/PH/C/E85, Graph1, Graph2
15. 06 SIC SS, 356whp, 302wtq, Verified Superflow, TS/3.25/60s/I/H/DP/E/T/WI/PH/TB, Graph
16. BlackMagic, 349whp, 302wtq, Verified Dynojet, TS/3.25/1000s/I/H/DP/T/HE/BRFPS/E85, Graph
17. SS/SC Crazer, 343whp, 300wtq, TVS1320/2.7/80s/IM/DU/CM/HE/I/H/CD/DP/E/FS/E85/P/T, Graph
18. SSFamilywagon, 341whp, 287wtq, Verified Dynojet, TVS1320/2.9/80s/E85/I/H/DP/CD/E/T/HE/DU, Graph
19. Sizzle06, 340whp, 276wtq, Verified Dynomite, TVS1320/2.9/79s/I/TB/H/DP/E/HE/DU/T, Graph
20. sput, 331whp, 276wtq, Verified DynoJet, TVS1320/2.9/80s/I/H/DP/T/DU/HE/E85, Graph
21. ebristol, 329whp, 290wtq, Verified DynoJet, TVS1320/2.9/80s/F/H/DP/CD/E/T/DU/HE/E85, Graph
22. JHans5774, 321whp, 281wtq, Verified Dynojet, TVS1320/2.9/79s/WI/DU/HE/I/H/E/CD/DP/T, Graph
23. Deathscythe, 313whp, 248wtq, Verified DynoJet, TVS1320/60s/PH/I/PI/WI/E/HE/T/DP, Graph
24. Billig_ss/sc, 303whp, 265wtq, Verified Dynojet, TVS1320/2.9/80s/H/DP/E/I/HE/TB/T, Graph
25. Staged07SS, 299whp, 242wtq, Verified Dynojet, H62/2.99/42s/PH/C/VS/TB/AM/GMHP/DP/CD/E/DU/OPTB/HE/RG/GM3, Graph
26. Jrhdpaintball, 297whp, 253wtq, Verfified Dynojet, TVS1320/3.1/60s/WI/H/CD/DP/E/T, Graph
27. drycell1218, 276whp, 237wtq, Verified Mustang Dyno, TVS1320/60s/I/H/DP/E/TB, Graph
28. ajm5036, 274whp, 242wtq, Verifed DynoJet, TVS1320/60s/I/H/DP/E/HE/T, Graph
29. 2K5SS/SC, 272whp, 239wtq, Verified Mustang Dyno, TS/I/T, Graph
2.0 LSJ Turbocharged - All Out POWER POTENTIAL (Turbo conversion, Twincharge, turbo + Nitrous)
1. Ryan@zzp, 898whp, 733wtq, Verified MustangDyno, All kinds of ****! lol Graph
2. InfraRedline, 654whp, 552wtq, Verified Dynocom, ZZP 2.1/TK s259et/PH/C/E/RS/160#s/E85/35psi, Graph
3. kjgcobaltss, 617whp, 519wtq, Verified Dynojet, T/160s/rs/tk/c/pi/e85/fs/pte6262, Graph
4. EXsoccer1921, 591whp, 477wtq, Mustang Dyno ZZP Block/Cams/80's/262/Stock head ports Graph
5. 06Blackg85ss, 563whp, 454wtq, Verified Dynojet, Graph
6. jhaddock21, 508whp, 445wtq, Dynojet, T/80s/RS/E85/ZZPtck/DP/s256et, Graph
7. Bluelightning 505whp, 368wtq, Verified Dynojet, S257sxe/80s/PH/C/NS/E/CD/T/E47/30psi, Graph
8. c130aviator, 472whp, 427wtq, Verified Dynomite I/H/DP/E/T/80s/BRFPS/TK/20g/CD/PH/IM/IC/FI/PI/E-85, Graph
9. Zooomer, 465whp, 414wtq, Verified Mustang Dyno E, T, 60s, TWNCHRG, CD, RG Graph
10. armcclure, 460whp, 350wtq, Verified Dynojet, I, F, H, DP, E, T, 115's, RS, TK, WI, CD, PH, IM, C, MD, E85, FS, Graph
11. 06blackg85ss, 438whp, 359wtq, Verified Mustang dyno TK, DP, E, T, I, 60s Graph
12. BlkWdoSS, 438whp, 333wtq, Verified, TK(S366)/80's/DP/E/IC/IM/RS/T, Graph1, Graph2
13. KangolRiot, 429whp, 376wtq, Verified Dynojet, I,F,H,DP,E,T,DU,80s,RS,GM2 Pulley,CD,HE,TB,PH,C,M62,TWNCHRG,CP,FI,PI,FS,OB, Graph
14. Tony54, 422whp, 365wtq, Verified Mustang Dyno, s256et,TB,80s,CD,I,E,T,ATI,VS,E85,IC,C,AFC ,CP, Graph
15. INFE, 420whp, 376wtq, Verified SAE corrected, Precision HP5857 Billet/H/IM/IC/CD/DP/CP/WI/79s/E/T Graph
16. DBLBoost, 419whp, 394wtq, Verified Dynojet I,DP,T,79,TK,WI,IM,PI Graph
17. Bl4ds, 417whp, 389wtq, Verified TK(S252et)/I/DP/E/WI/60s/T Graph
18. Maxim_X, 417whp, 363wtq, Verified I/DP/CD/E/TK(GT35r)/80s/T/WI/IM(saab) Graph
19. MP Cobalt, 413whp, 382wtq, Verified Dynojet, TK(256et)/T/80's/E Graph1,Graph2
20. Mybadss, 410whp 377wtq, Verifed Mustang Dyno TWNCHRG, DU, 60s, E, DP, CD, T Graph
21. INFE, 407whp, 354wtq, Verified Dynojet, GT3076r TK/IM/DP/79s/IC/T/E/I Graph
22. Bluelightning, 406whp, 340wtq, Verified Mustang Dyno, s252et/80s/PH/C/VS/E/CD/T/E45/27psi, Graph
23. Jared B, 404whp, 370wtq, Verified Dynojet, ZZPTK/60's/E/T/23psi, Graph
24. jonnymerk, 347whp, 308wtq, Dynojet TK/IM/72s/DP/CB/IC Graph
25. Dayta, 342whp, 328wtq, Verified DynoJet TK, CD, E, 60s, T, 22psi Graph
26. jmarks, 338whp, 312wtq, Dyno Dynamics,I,H,Custom DP,ET,80s,TK,CD,IM,IC,Custom CP Graph
27. glen229, 230whp, 245wtq, Verified DynoJet tk,cd,e,t,60s,IC,CP @4psi Graph
2.0 LNF Turbocharged - K04 Power
1. 09whteSSpssssh, 367whp, 445wtq, Verified DYNOmite CP/CD/DP/E/I/IC/E47/HPT Only Graph 1 Graph 2
2. Frogstofall, 362whp, 376wtq, Verified Dynojet, I/DP/T/GM1/IC/CP/E47, Graph
3. colodude18, 359whp, 418wtq, Verified Dynojet, K04/T/I/IC/DP/CP/E/E-85, Graph
4. raver0789, 359whp, 408wtq, Dynojet, I/CP/IC/DP/CB/E47 Graph
5. taintedred07, 356whp, 430wtq, Dynojet, I/DP/E/T/C/IC/CP/K04/E-85/GM1S, Graph
6. jcalvin1126, 354whp, 379wtq, Verified Dynojet, K04, I, DP, E, CP, T, IC, GSM1S, E47, Graph
7. FF_ace 351whp, 393wtq, Verified Dynojet, CAI/CP/IC/DP/CD/E/WI/E85/T Graph
8. 09CobaltSS1, 351whp, 388wtq, Verified Dynojet, KO4,I,DP,E,T,IC,CP,GM1S,E47,25psi, Grpah
9. Canadia, 351whp, 377wtq, Verified Dynojet, I/DP/CBE/FMIC/UCP/T, Graph
10. Cavalierssr, 350whp, 439wtq, Verfied Dynojet, I/DP/CD/CP/MD/T/E85, Graph
11. cblt2469, 349whp, 400wtq, Verified Dynojet, I/IC/DP/E/T/UPPER CP/K04/E47/GM1S,
12. mongorat427, 349whp, 363wtq, Verified Dynojet, I/E/CP/IC/T, Graph
13. BYT*SS*TURBO 347whp, 414wtq, Verified Dynojet, DP/CD/CP/I/T/IC, Graph
14. 2010SS 346whp, 426wtq, Verified Dynojet, DP/IC/I/CP/E85/T, Graph
15. vahdyx, 347whp, 397wtq, Verified Dynojet, I,E,DP,T,TK,IC,CP,K04, Graph
16. JBThrasher22, 346whp, 399wtq, Verified Dynocom, GM1S, I, DP, T, Graph
17. leemanfor, 344whp, 457wtq, Verified Dyno, I/DP/CP/BOV/E85, Graph
18. 09BlueBaltSS 344whp, 384wtq Verified Dynocom T/I/DP/CD Graph
19. 09whteSSpssssh 343whp, 423wtq Verified DYNOmite I/DP/CD/CP/IC/T/WI Graph1Graph2
20. D-mac, 337whp, 386wtq Verified Dynojet I,DP,T,WI,GM,CD,IC,CP Graph
21. oowah, 334whp, 354wtq, Verified Dynojet, I/DP/CP,T, Graph
22. Projekt 331whp, 393wtq Verified Dynojet I/CD/DP/T Graph
23. BlueBetaFish11, 330whp, 389wtq, Verified Dynojet, (289whp, 326wtq Mustang), I/E/IC/CP/T Graph1 Graph2
24. Gremlin85, 328whp, 421wtq, Verified Dynojet, I/DP/E/IC/CP/T, Graph
25. BYT*SS*TURBO 327whp/386wtq DP/CD/CP/I/T Graph
26. BoostedYards86, 327whp, 384wtq, Verified Dynojet, I/CP/IC/DP/GM1, Graph
27. beast10007 326whp, 368wtq Mustang Dyno, GMS1/CP/IC/I/E85 Graph
28. Tdubbs, 326whp, 357wtq, Verified dyno, I/DP/E/CP/IC/GMS1/T, Graph
29. RKRamos, 325whp, 402wtq, Verified Dynojet, I/DP/E/HPT/CD/IC/CP Graph
30. dbr, 325whp, 364wtq, Verified Dynojet, I/T/SM/IC/CP/ST/C/E85, Graph
31. 1LSJ2NV, 324whp, 421wtq Dynojet, I/DP/T/IC/CP/K04, Graph
32. sc4door, 324whp, 346wtq, Verified Dynojet, I/E/T/DP/IC/CP/WI/GMS1/25psi, Graph
33. mongorat427, 322whp, 374wtq, Verified I/E/CP/IC/T, Graph
34. nmoe330, 321whp, 378wtq, Verified Dynojet, I/DP/T/CD/CP/MD/24psi, Graph
35. boosted4dr 321whp, 335wtq Verified WinDyn, GMS1, IC, DP, CP, AM GRAPH
36. EFoxwell, 320whp, 350wtq, Verified Dynojet, I/DP/E/IC/CP's/Trifecta 23psi, Graph
37. ginger, 320whp, 339wtq, Verified Dynojet, I/IC/CP/DP/E/T/23psi, Graph
38. AARON-SS-TC, 317whp, 384wtq, Verified Dynojet, I/IC/DP/MD/T 24psi, Graph
39. KnightSS/TC 317whp, 349wtq Verified Dynojet I/CP/IC/DP/CD/T Graph
40. Cavalierssr 316whp, 389wtq Verfied Dynojet I/DP/CD/CP/MD/T Graph
41. ecotecturbo, 316whp, 366wtq, Verified Dynojet, T,I,CD,DP,E,IC, Graph
42. Piston3, 315whp, 339wtq, Verified Dynocom, LDK/I/DP/T/IC/CP/K04/GM1S, Graph
43. ch1ck3n 314whp, 388wtq Dynojet dyno CD/F/T/E-85 Graph1Graph2
44. ChillenGillon, 314whp, 373wtq Verified Dynojet, I/E/DP/GMH/CP/CD/T Graph
45. FrankMullet, 312whp, 350wtq, Verified Mustang Dyno, I/DP/E/WI/IC/CP/E47/T, Graph
46. dayhoff35, 312whp, 331wtq, Verified Dynojet, I/DP/CP/T Graph
47. AcesNEights 311whp, 390wtq Verified CD/DP/E/T Graph
48. Baron7700 310whp, 361wtq Verified Dynojet I/DP/CD/GMS1/T HP Graph TQ Graph
49. ronn 308whp/360wtq Verified Dynapack T Graph
50. Hunter19707, 307whp, 345wtq Dynojet Dyno, I/CP/DP/IC Graph
51. Cobe, 304whp, 358wtq, Dynojet, T/I/DP, Grpah
52. m33pm33p, 302whp, 342wtq, Verified Dynojet, T/DP/CP/20psi, Graph
53. Batboy, 301whp, 345wtq Dynojet I, DP, CP, IC, Tune Graph
54. casionerd, 300whp, 359wtq, Verified Dynojet, I/DP/GMS1S/CP/T, Graph
55. 1SLOLT1 300whp, 335wtq Verified GMS1/CD/DP Graph
56. CudaJoe 298whp, 327wtq Verified Dynojet T, I, CP, IC, BPV, DP Graph
57. Stephenishere, 292whp, 379wtq, Verified Dynojet, I,T,IC,CP,MD,24psi, Graph, Chart
58. Cubaniche 291whp I, DP, CP, Tuned Graph
59. Black08SSTC 289whp 314wtq Verified Mustang Dyno T, I, CP Graph
60. 09cobalttc, 283whp, 323wtq, Verified Dynojet, I/DP/E/IC/CP/GMS1, Graph
61. Tdubbs, 283whp, 314wtq, Verified Dyno, AM/F/T, Graph
62. MTE, 283whp, 267wtq, Verified Mustang Dyno, I/CP/DP/E/T Graph
63. 80VetteL82 277whp, 302wtq Dynojet, GMS1/I Graph
64. overboostedss 269whp, 271wtq Mustang Dyno I/DP/CB/CP/IC/Stock Tune Graph
65. Cobalt Daddy, 268whp, 291wtq, Verified Dynojet, GMS1, Graph
66. YelloEye, 267whp, 264wtq, DynoJet, AM/DP/K04,19.5 psi Graph
67. tjsz 254whp, 306wtq AB/T Graph
68. lnfftw, 249whp, 262wtq Verified Dynojet, F, E Graph
69. Guy SS-TC, 244whp, 256wtq, Dynojet, Graph
70. 09SS 239whp, 237wtq Verified Dynojet MD, F Graph
71. MikeyG 239whp, 233wtq Verified Dynojet, Graph
2.0 LNF Turbocharged - All Out POWER POTENTIAL (Big Snail, Built Motor, Nitrous)
1. Matt M (ZZP), 607whp, 547wtq, Verified Mustang TK/CP/IC/CAM/CB/E85 Graph
2. KMO43, 511whp, 427wtq, Verified Dynojet, 7163/CAI/IC/HP/CP/CD/E/T/27PSI/E30/WI/GM1S/PH/IM/C/VS, Graph
3. FasterIsBetter, 508whp, 473wtq, Verified Mustang Dyno, E/T/ZZPtk/PI/PH/FI/E85/OB/FS/CP/IC/C/GM1S/CD/ZZPGirdledBlock, Graph
4. raver0789, 508whp, 404wtq, Verified Dynojet, ZZPtk(s259et)/GM1S/RG/E/CP/T, Graph
5. cmiller8006, 501whp, 447wtq Verified Mustang Dyno, E, T, ZZPtk, CD, TB, C, RG, IC, CP, FI Graph
6. gone_in_10_sec, 486whp, 517wtq, ZZPtck/H/DP/CD/SRI/CP/IC/T/C02/N2O-75/RG Graph
7. KMO43, 482whp, 400wtq, Verified Dynojet, 7163/CAI/IC/HP/CP/CD/E/T/28PSI/E25/WI/GM1S, Graph
8. colodude18, 479whp, 471wtq, Verified Dynojet, 4.45/ZFR/T/I/IC/DP/CP/FI/E/E-47, Graph
9. 1badBlueberrySC, 455whp, 410wtq Verified Dynojet, PTE2871r(22psi)/H/DP/CD/CP/WI/T/E Graph
10. Wert842, 446whp, 405wtq, Verified Dynojet, ZFR/T, Graph
11. 09CobaltSS1, 437whp, 408wtq, Verified Dynojet, EFR6758,I,DP,E,T,IC,CP,GM1S,5th Injector,E47,26psi, Graph
12. Kdub1492, 430whp, 433wtq, Verified Mustang Dyno, I,E,CD,IC,CP,FI,MD,PI,GM1S,WR-3, Graph
13. 09CobaltSS1, 422whp, 406wtq, Verified Dynojet, EFR6758,I,DP,E,T,IC,CP,GM1S,E35,25.5psi, Graph
14. Team SS, 415whp, 381wtq, Verified Dynojet, I,DP,T,CD,IM,C,IC,CP,FI,PI,GM1S, Graph
15. CMVsst2010, 411whp, 374wtq, Verified Mustang Dyno, S256et/DP/IC/CP/I/T, Graph
16. r3v07ut10n, 410whp, 377wtq, Verified Dynojet, GMS1/DP/CP/I/T/WI/CD/IC/RG(94)/ZFR, Graph
17. Frogstofall, 408whp, 383 wtq, Verified Dynojet, I/DP/T/GM1S/E47/IC/CP/BNR2871(24.5psi), Graph
18. FrossB, 407whp, 391wtq Verified Dynojet, PT5557/I/CP/H/E/T/IC/ 91oct.
19. Donkeyballs 398whp, 397wtq Verified DynoJet IC/CAI/CP/DP/CD/T/TK EFR6758 23psi Graph
20. Chevycobaltss3, 398whp, 394wtq, Verified Dynojet, TK(20g)/I/CP/DP/E/IC/T, Graph
21. Mezzano 381whp/381wtq Verified SAE corrected GT3076r/CP/IC/DP/CD/E/T Graph
22. jmarks, 373whp, 401wtq, Verified Dyno, GT3076/I/E/T/TK/CD/IC/CP, Graph
23. gone_in_10_sec, 370whp, 380wtq ZZPtck/H/DP/CD/IC/CP/I/T/C02 GRAPH
24. mkriebs, 368whp, 387wtq Verified Mustang Dyno IC/CD/DP/Werks 5557 TK/T Graph
25. badbaltguy, 356whp, 363wtq Verified DynoJet IC/CAI/CP/DP/CD/E/T/s20g(25psi) HP Graph TQ Graph
2.4L LE5 - Naturally Aspirated
1. noorjariri, 201whp, 188wtq, Verified Mustang Dyno, I,F,H,DP,E,T,TB Graph1,Graph2
2. newt, 193whp 179wtq,Verified Dynojet, I,F,H,T,42s,TB,PH,C,CO, Graph
3. Hotpursuit, 170whp, 174wtq Verified Dynojet, I,Fr,H,DP,E,T,DR,CD,CO, Graph
4. steddy2112, 167whp, 166wtq Verified, I, E, Graph
5. DiabeticKripple, 162whp, 153wtq, Verified, I, E, T, Graph
2.4L LE5 - Anything Goes
1. Mobile Chassis Dyno, 406whp, 463wtq, Dynojet Dyno ZZPtk/E85/Stock Motor! Graph
2. elecblue06, 342whp, 397wtq, Verified Dynojet, 80s/BNR/DP/E/FMIC/tune/E85/16psi, Graph
3. noorjariri, 320whp, 283wtq, DYNOmite Dyno, TK(Comp5556@10 psi)/E85/CD/T/IC/E/80s, Graph
4. glen229, 303whp, 321wtq Verified Dynojet (50trim 10psi)TK/60s/T Graph
5. Cherry_GT, 271whp/275wtq Verified TK(s256et 10psi)/DP/E/CD/I/CP/IC/T Graph
6. hhrfreek, 257whp, 233wtq Verified Dyno, I,F,GMH,DP,E,T,60s,3.1,M62,PB,CD,HE,TB,C, Graph Graph
7. elecblue06, 251whp, 208wtq Verified WinDyn H, DP, E, T, PCK, 3.2, 60s, m62 Graph
8. Zdeuce4, 247whp, 267wtq Verified Mustang Dyno (50trim 12psi)TK/E/T/60s Graph
2.2L L61/LAP - Naturally Aspirated
1. NWAE_Cobalt, 180whp, 164wtq, Verified DynoJet I, IM, TB, PH, 42s, C, H, DP, CD, E, P, T Graph
2. Copson20, 163whp, 150wtq Verified DynoJet I, IM, H, DP, E, T, TB, C, Graph
3. NWAE Cobalt, 154whp, 157wtq Verified I, E, T, DP, H Graph
4. Brags 143whp, 131wtq Mustang Dyno I, H, E, DP, IM,T Graph
5. UNIJABNX2000, 142whp, 141wtq Verified Dynojet, STOCK Graph
6. GBRunner24, 142whp, 140wtq, Verified Mustang Dyno, I/H/DP/E/IM/T, Graph
7. agita san, 140whp, 127wtq, Verified Dynojet, T, I, H, DP, E, IM, Graph
8. springerdesigner, 138whp, 136wtq Verified Dynojet I/H/DP/E/T Graph
9. montecarloman, 138whp, 133wtq Verified Dynojet, I, TB, IM, E, T Graph
10. huckernage, 127whp, 127wtq Verified Mustang Dyno, I/H/DP/E Graph
11. MP81, 124whp, 134wtq, Verified Dynopack, STOCK, Graph
12. 007CobaltLS, 112whp, 110wtq, Verified Dyno Dynamics, STOCK Graph
2.2L L61/LAP - Anything Goes
1. lwpmoon, 539whp, 526wtq, Verified Dynojet, H,DP,E,T,80s,TK,TB,IM,C,IC,FI,E-85, Graph
2. 07blackg5, 453whp, 335wtq, Verified Dynojet, TVS1320, 2.7, ATI OD, I, TB, H, CD, IM, HE, OPTB, PH, C, VS, BS, FI, e85, RS, 114s, Graph
3. conerboner, 355whp, 342wtq, Verfied Dynojet, i,e,h,t,tb,cd,he,ic,im,cp,fi,zzptk,fs(brfps),80s,e-85 bullseye s256 @ 13 psi, Graph
4. BankerBalt, 348whp, 296wtq, Verified Dynojet, I,f,h,e,t,80s,tk,cd,tb,ph,im,ic,cp,fi,md,pi,e85 @ 12psi, Graph
5. killswitch1209, 346whp, 333wtq, Verified Dynojet, I,F,H,T,MD,CD,IC,CD, FI, DP e85, 80's, 15 psi, Graph
6. Brags, 319whp, 274wtq, Verfied Mustang, I,H,E,T,TK,DP,CD,TB,PH,IM,SM,IC,CP,FI,FS Werks 5557 14psi Graph
7. GSDIESEL300, 267whp, 215wtq, Verified Dynojet, (LAP Auto), M62/PB/2.9/60s/HE/DU/I/F/TB/IM/T, Graph
8. Foximus, 242whp, 204wtq, Verified Dynojet, I,F,H,DP,E,T,42s,HE,PH,C,M62,FI,PI,VA, Graph
9. Leafydialupking, 226whp, 213wtq Verified Dynojet, F/H/E/T/DU/60s/RS/2.8/HE/M62, Graph
10. springerdesigner, 225whp, 200wtq (Auto) Verified Dynojet M62/3.08/60s/HE/CM/DP/H/E Graph
11. stenguyen1, 224whp, 225wtq, Graph
12. MP81, 219whp, 208wtq, Verified Dynojet, (Auto) E,T,42s,2.9,HE,TB,M62,AM, Graph
13. drumrush, 213whp, 199wtq, Verified Dynojet, m62/3.0/I/h/dp/e/he/60's, Graph
Legend:
I = Intake
F = Filter
H = Header or Aftermarket/other than stock Turbo Manifold
GMH = GMPP Extrude Honed Manifold
GMHP = Ported GMPP Extrude Honed Manifold
DP = Aftermarket Down pipe
E = Cat-back exhaust
T = Tuning
P = Underdrive Pulley
DR = Drag Radials or Slicks
DU = Dual Pass
98s = 98# injectors
80s = 80# injectors
79s = 79# injectors
60s = 60# injectors
50s = 50# injectors
42s = 42# injectors
RS = Return style fuel system
N2O[shot] = Nitrous + shot
0.0 = Will specify pulley size for the SS/SC's
WI = Water/Meth Injection
PB = Ported Blower
GM1 = GM Stage 1
GM2 = GM Stage 2
GM3 = GM Stage 3
I-STGx = Intense Stages
CD = Cat Delete
HE = Aftermarket or 2nd Heat Exchanger
TB = Ported or aftermarket throttle body
PH = Ported, aftermarket head/headwork
IM = Ported,aftermarket, or better than stock intake manifold
C = Cams
M62 = Stock Supercharger off a Cobalt SS/SC
H62 = Hybrid M62
TVS1320 or TVS1900 = TVS supercharger
TS = Twin Screw supercharger
TWNCHRG = Twin Charged (turbo and supercharger)
TK = Turbo Kit
RG = Race or above 93 octane gas
AM = Airbox mod
IC = Intercooler
CP = Chargepipes
FI = Forged Internals
ZZPtck = ZZP turbo conversion kit
ZZPtk= ZZP turbo kit
CO = Exhaust cut out
PCK = Procharger Supercharger kit
MD = Muffler Delete
K04 = K04 turbo
PI = Pistons
E85 = Ethanol Fuel
FS = Fuel System upgrade
STR = Stroker (anything with a longer stroke than stock)
OB = Overbore
GM1S = GM Stage 1 Sensors (SS/TC)
BS = Balance shaft delete
OPTB = Option B
VS = Valve springs
FPRW = Fuel Pump Rewire
CR 0:0 = Compression Ratio
Someone update this list, lots happed in 10 years 😂
Old Nov 4, 2025 | 11:57 AM
  #549
DFZ24's Avatar
I would be 2nd place on 2.4 anything goes! 🤣 Just took me over 15years to get there lol
Old Feb 10, 2026 | 02:45 PM
  #550
jdbaugh1's Avatar
I never uploaded this years ago. Does this page still get updated? 341wtq 366whp
341Wtq/366whp
341Wtq/366whp
Staged07SS
Oct 25, 2013 07:33 PM
BYT*SS*TURBO
Feb 21, 2012 01:02 PM
ralliartist
Dec 30, 2011 11:39 PM
ralliartist
May 19, 2011 02:34 AM
Khase
Mar 30, 2011 11:10 PM
