Dyno Results Dyno pictures, videos and dyno results.
TVS dyno
Old Apr 18, 2010 | 08:04 PM
Jrhdpaintball's Avatar
TVS dyno
mods are:
tvs, 3.1 pully, 60lbers, meth 90/10 mix 5gph nozzle, 3" zzp intake, zzp mid length header 1.75/3" catless downpipe, hahn 3" catback, 2 step colder plugs, hptuners, single pass w/ opt. B, cx racing big front mount
7500 redline, wish i could of went higher. my other motor will
i think thats it for power mods.
Run 1:289hp/257tq 23 Deg. max timing, afrs are 12.2 - 11.8 by redline
Run 2:291hp/253tq 24 Deg max timing, 12.4 - 11.9 by redline
Run 3:297hp/253tq 25 Deg max timing, 12.2 - 11.8 by redline
Run 4:294hp/251tq 25 Deg max timing, 11.9 through out
MAF lb/min on run 3: 43 lb/min
MAF Hz on run 3: 10600 Hz
Old Apr 18, 2010 | 08:08 PM
Cefaln452's Avatar
whos the tuner?
Old Apr 18, 2010 | 08:15 PM
Supercharged Guy's Avatar
Those #'s look kinda low for that setup, I've seen guys with the 3.1 w/o meth run in the 3's
Old Apr 18, 2010 | 08:18 PM
EXsoccer1921's Avatar
not bad for the 3.1. i'm glad i have a good tuner, thats only 24whp and 3wtrq higher than my m62 dyno. hahah, but granted its just the 3.1
Old Apr 18, 2010 | 08:20 PM
its a wickedtoon.. partially, i had to modify a little for meth.
i was satisfied, i wanted 300, but o well.
ive got a 2.9 pully, and 80lb injectors for after i try this set up at the track.
from what ive seen on here most 3.1 pullys are putting out simular results. i mean i wish i had some of areas pixie dust, but i made due with what i had lol
Last edited by Jrhdpaintball; Apr 18, 2010 at 08:20 PM. Reason: Automerged Doublepost
Old Apr 18, 2010 | 08:21 PM
You should be able to get 3 pretty easy and if you drop the pulley size down to a 2.8 or a 2.9 then you deff will get over 3 without a dout.
Old Apr 18, 2010 | 08:25 PM
yea defantly, no worries tho, just numbers...im still pretty new at tuning, especially at the dyno getting the most out of it. i think im going next weekend with the same setup and just try off the wall things just to see what the differance is. differant timing maps, im going to see if running richer hurts it alot.
the only thing ive pretty much learned after this is, find peak torque, and where that is should be your max timing. then from there keep timing the same or taper down slightly. anyone else heard of this?
Old Apr 18, 2010 | 08:28 PM
freakta's Avatar
it all depends on what your car wants to do as well. my car was adding timing as soon as i hit the meth
Old Apr 18, 2010 | 08:32 PM
forgot to mention single pass
on 3rd run
iat1 - 70
iat2 -started at 104 ended at 126
SmitBag
Sep 7, 2016 08:05 AM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
