**Need help with compatibility issue, Quick Question**
Old May 18, 2013 | 08:21 PM
xtremecavy's Avatar
Will a Pioneer avh-p1400 installed in an 07 SS be plug and play into my 05 SS?? i think the stock head units are different but he has the harness and its in an 07 now, mines an 05 and i was going to buy it!!! Thanks!!
Old May 18, 2013 | 08:28 PM
Joe22's Avatar
Ya the plug is the same.. The difference will be working with Pioneer system and/or Onstar. Depending on what harness is used.
Old May 18, 2013 | 08:29 PM
xtremecavy's Avatar
do you care to explain what you mean??? he said his steering wheel controls work now, i think he has the axxess plug, he said it was about an $80 plug and everything worked as it now!!
BTW i dont have onstar anyhow
Last edited by xtremecavy; May 18, 2013 at 08:29 PM. Reason: Automerged Doublepost
Old May 18, 2013 | 08:33 PM
chevygirl2006's Avatar
you can get a different harness to keep your steering wheel controls. its called PAC and its only like $40 and if you want to keep your stock chimes you will need another harness. thats the expensive part.
Old May 18, 2013 | 08:37 PM
this is what you will need
Scosche MDA1B Antenna Adapter for 1988-up for Chevrolet / GM
http://www.ebay.com/itm/NEW-PIONEER-SWI-RC-SWI-PS-INTERFACE-AFTERMARKET-STEERING-WHEEL-RETAIN-CONTROL-/360529245642?pt=US_Adapters&hash=item53f137b5caScosche GM13SR GM/ LAN Stereo Replacement Interface Module for[query_id]=20225290&SearchClickout[Ignore]=1
Metra 95-3302 (met-953302) Dual Single DIN or Double DIN
Old May 18, 2013 | 09:09 PM
xtremecavy's Avatar
But he said his steering wheel controls work with it.....so will i need anything or does he already have it
Old May 18, 2013 | 09:11 PM
Joe22's Avatar
Thats good. Metra Axxess sterring wheel controls is a better module than the PAC. The harness is what I was talking about though for the actual car. It's either a module like the steering wheel controls or its just a regular harness with wires and no module. I'd assume he bought the module and did it the right way if he bought the steering wheel controls, I'd say yes should be plug and play.
Old May 18, 2013 | 09:13 PM
xtremecavy's Avatar
Is there anything to worry with about loosing anything else?
Old May 18, 2013 | 09:17 PM
I'm just telling you everything I bought. I just got mine installed on Thursday. And the PAC works perfect.
Old May 18, 2013 | 09:30 PM
xtremecavy's Avatar
im just afraid something is different with the 05 and 07 and i hate to buy it if its not all going to work...the price im getting it is good for a plug and play setup but not if i have to buy all new interfaces and harnesses
Old May 18, 2013 | 09:48 PM
xtremecavy's Avatar
Ok he gave me the module interface number , its a GMOS-LAN-04.....will that work on my 05 SS
Old May 18, 2013 | 09:51 PM
That one say its to keep on star and is for 06 and up. But I bought an 07 and up for my 06 and it still worked.
Old May 18, 2013 | 09:55 PM
xtremecavy's Avatar
Can someone confirm if the GMOS-LAN-04 will work in an 05 ss??
Old May 19, 2013 | 03:12 AM
EmperorJJ1's Avatar
it will not work at all
Old May 19, 2013 | 10:26 AM
xtremecavy's Avatar
Thanks again!!
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
