*sneak peak* audio related
Old Nov 22, 2009 | 07:21 PM
slowswap's Avatar
I plan to write up a full how to along with pictures for this build but figured I'd give the audio guru's a sneak peak of whats to come.
Old Nov 22, 2009 | 07:22 PM
Black SS/SC 06's Avatar
What if it doesn't get approved?
slowswap's Avatar
Then I share no more knowledge!!! lol
I have a lot of good info.
Old Nov 22, 2009 | 07:23 PM
dman090's Avatar
hmm where is this gonna go?
Old Nov 22, 2009 | 07:24 PM
slowswap's Avatar
In the back of a Cobalt.
jschatte's Avatar
that thing is huge! that kinda sub is going in there
We shall see
Old Nov 22, 2009 | 07:26 PM
slowswap's Avatar
Audiobahn AW1251T. Net box volume is 2.5 cu ft.
Old Nov 22, 2009 | 07:27 PM
dman090's Avatar
im defiantly looking foreward to a how to
sexy
Old Nov 22, 2009 | 07:28 PM
slowswap's Avatar
sexy
That's what she said.
Old Nov 22, 2009 | 07:29 PM
glen229's Avatar
is that thing gonna be built in the trunk, doesnt look like its gonna fit, but thats just me
Old Nov 22, 2009 | 07:31 PM
slowswap's Avatar
Should slide in through back seat opening. Going to be a close one though. I need to take some more precise measurements.
If not, that's what they made big ******' hammers for.
Old Nov 22, 2009 | 09:09 PM
brickloaf's Avatar
are you sure you can fit 30" wide in the trunk?
it will forsure go through the trunk lid opening but you might have to have it sitting right up against the back wall
you will forsure be able to fit 2.5 cubes
ive got 3.9 cubes total and goddamn its a BITCH to get out
Old Nov 22, 2009 | 09:15 PM
slowswap's Avatar
I'm going to make a box out of cardboard with the same outside dimensions so I can see if it'll fit. No sense in building something if it doesn't go in the car. I lifted some max dimensions from a thread on this site that will fit in the trunk, and I built smaller then those.
I should be able to get some measurements tomorrow and verify.
EDIT: Net is 2.5 cu ft but gross is 3.46 cu ft.
Old Nov 22, 2009 | 09:22 PM
kkanowitz's Avatar
I had an older installer buddy at Circuit who built a box similar to this... Lets just say it was obnoxiously ridiculously loud. and that may still be an understatement.
Old Nov 22, 2009 | 09:27 PM
slowswap's Avatar
Let's just say I'm mildly insane. We're pushing 300 watt RMS to this sub yet it will probably blows most peoples 1000+ watt systems away. Yay for 8 gauge speaker wire! lol
Old Nov 22, 2009 | 09:32 PM
kkanowitz's Avatar
hahaha exactly! I don't remember what speaker he had, but I know he was only running 500 or so watts. I honestly don't think a 1500 watt system was able to compete... and what was even funnier is that he didn't paint the box or do any cosmetic work. He just tossed it in the trunk of that grand prix, tossed the amp in and power'd 'er up!
Old Nov 22, 2009 | 09:52 PM
brickloaf's Avatar
ehh 300w isnt much, idk about beating 1000+
8g is speaker wire is overkill even for me and im pushing 2500 rms
Old Nov 22, 2009 | 10:04 PM
slowswap's Avatar
Overkill? Not really. You have to eliminate all places that can cause inefficiency.
Most people have there 1000 watt 2 ohm amp hooked up in series to 2x 4 ohm dual voice coil subs in sealed enclosure that's 1/2 the required size.
Do you see what I'm getting at?
Old Nov 22, 2009 | 10:05 PM
dom1013's Avatar
*awaiting some numbers from a verified meter*
I forsee a 138.5 maybe a 140 if you crack the door at its peak.
That's box will definitely take out a lot of prefabs w/2 12's and 1000watt amps...and 1000watt system with a properly built set-up...eehhh. People don't understand if they'd actually just get a properly built box their systems would be so much better.
Cool, non the less...I like to see more audio stuff
Old Nov 22, 2009 | 10:07 PM
slowswap's Avatar
That is exactly what I'm getting at.
Old Nov 22, 2009 | 10:12 PM
brickloaf's Avatar
what hz are you tuning to?
also i read an article with real numbers and at 1 ohm 8g can take like 15k rms...ill try to find the article
Old Nov 22, 2009 | 10:13 PM
Spun's Avatar
I hate to be the only one that see's a problem here but hey its in my nature
Take it from someone who has there subs facing up, don't do it!
My subs are in a tub in the spare tire well, and even with 2 layers of sound deadner on the bottom and 3 on the top that back deck lid rattles like an S.O.B.
Other than that, you seem to have a good idea of what you want and how to get there, I'm just trying to warn you about the sub facing up, face it to the rear, face it to the front, just don't face it up, don't port it up either....trust me.
dom1013's Avatar
we're on the same page...
