07 LS 25K - Heat Issues
About the car... 2007 LS sedan, 25k miles, everything stock. been up with all maintenance.
issue... when i kick on the heat, it takes a little to get warm, as any 4 cylinder does. this is not the issue... however, once the car is nice and warm, i turn down the heat to enough to maintain the cabin temp. but when i take turns, both left and right, it feels like an inferno is flaming out of my vents and it is incredibly hot throughout the turn. once the wheel is straight, the temp goes back to normal. this occurs regardless of whether the outside vents are open or not, with no difference. (of course being the winter, they are closed more often other then when trying to troubleshoot this)
someone mentioned something about a vacuum leak, but there is no evidence of such.
any idears?
any idears?
im going to take a stab in the dark and say that your blend door somehow got really f***ed up. so every time you turn its just swinging wide open and letting unrestricted air past your heater core.
just an idea
just an idea
