10 volt wire on radio harness
Old Nov 17, 2006 | 02:49 PM
toddsbalt's Avatar
what is the 10 volt wire used for on the radio harness?
Old Nov 17, 2006 | 03:22 PM
Bandit2941's Avatar
?? You're probably probing the of the GM LAN communication wires....
Old Nov 17, 2006 | 09:07 PM
toddsbalt's Avatar
if you look at the sticky about the wiring diagram there is a wire thats for 10 volt then another wire for the gm lan??
Old Nov 19, 2006 | 09:23 AM
zinner's Avatar
Moderator Alumni
I am pretty sure the 10 volt is a reference voltage for the steering wheel controls.
The controls are a set of resistors and the button you are pushing determines a certain resistance and a voltage drop and the radio processes that a know you hit volume up ect.
Old Nov 19, 2006 | 10:52 AM
Bandit2941's Avatar
Good call, you're right. The radio supplies that wire with 10 volts, and that powers the resistor network for the steering wheel controls. When I put a new HU in and wired up a PAC SWI-ALP, I had to supply that wire with 12volts so the resistor network had power.
Here's directions from the PAC website:
# Connect the INTERFACE's Green wire to...Pin A9 Dark Blue of the above connector
# Connect Pin A10 White/Black to +12 volts accessory.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
agentirons
Oct 16, 2015 02:11 AM
jmelton327
Sep 26, 2015 10:04 PM
