1000w RMS <$100
Old May 11, 2008 | 09:45 PM
Xenozx's Avatar
1000w RMS <$100
OK, so I am doing some investigation and just thought I would ask why prices vary so much when it comes to amps? By this I mean, I found this amp
http://www.sonicelectronix.com/item_...ik+V408XT.html
is <100 bucks and is 500x2 @ 2 ohm. I figure this would power a pair of Type R's without fail right?
How come a comparible alpine amp costs 500 bucks?
Is there something I am missing?
Wont a Visonik 500x2 @ 2 ohm RMS amp run the speakers just the same as if I used a Alpine 500x2 @ 2 ohm RMS ?
also is that a good combo? 2 type R's w/ a 2 channel 500w rms amp?
Old May 11, 2008 | 09:48 PM
HackAbuse's Avatar
only 50amp worth of fuses for a "1000w RMS Amplifer"?
I call bullshit.
Old May 11, 2008 | 09:49 PM
SSRedSC's Avatar
No way thats RMS. It has to be peak, if that.
Old May 11, 2008 | 09:50 PM
halfj99's Avatar
its called quality my friend, well that and paying for a name
SSRedSC's Avatar
The old saying is generally true, especially in a situation like this... You get what you pay for. I wouldnt buy it but thats just me.
Old May 11, 2008 | 09:54 PM
KillerBee's Avatar
I ordered my kenwood from there with the same exact watts for 129.99
Old May 11, 2008 | 09:56 PM
HackAbuse's Avatar
I'm saying, I had two monoblock amps from Soundstream that did a true 1000w RMS and they used 90 amps worth of fuses, and these things were EFFICIENT AS HELL.
Efficiency = the ability to convert power into sound without losing it as heat.
Higher Efficiency = More output wattage per input wattage.
There's no way an non-class-D amplifier is going to put out 1000w RMS while using less than 50amps for less than 100 bucks
Impossible.
Even my old sony amps that put out 500w RMS use 80 amps of fuses.
Old May 11, 2008 | 09:59 PM
KillerBee's Avatar
Impossible.
Yeah but either his nor my kenwood is a 1000 watt rms that bridge wattage on the visonik by 1 channel is peak power not rms
Old May 11, 2008 | 10:07 PM
elecblue06's Avatar
that place is actually running extremely good deals .. but thats definately not RMS. thats for damn sure
Old May 11, 2008 | 10:09 PM
KillerBee's Avatar
yeah they always got awsome prices i buy a lot of my stuff from them all the time. But yeah how could a 1000 watt peak power push 1000 watt rms its not possible
Old May 11, 2008 | 10:11 PM
blksscharged's Avatar
go to Onlinecarstereo.com instead its better. The deals are much better there and you can get stuff for a good deal.
Old May 11, 2008 | 11:06 PM
07cobaltscss's Avatar
I agree, Online Car Stereo have some way good deals. but with car audio im usually one to buy something thats made from a "big name" company.. thats just me. But it comes down to money! 99 bucks for an amp with those ratings.. why not at least try it?
Old May 11, 2008 | 11:23 PM
Xenozx's Avatar
yea, I think ill pass on that amp, but to power 2 Type R's X's, I am looking for a 500w x 2 RMS @ 2 ohm amp right?
hows this?
http://www.onlinecarstereo.com/CarAu...roductID=16850
Old May 11, 2008 | 11:30 PM
elecblue06's Avatar
http://www.onlinecarstereo.com/CarAu...roductID=17926
it's more expensive on onlinecarstereos
Old May 11, 2008 | 11:45 PM
CleanNFun's Avatar
I bought an alpine amp, with my 10' type r, and it sounded pretty good, if your buying alpine why not stick with alpine? why pay a little more for a sub then less for an amp....
Old May 12, 2008 | 02:01 AM
EmperorJJ1's Avatar
hahah visonik and 1000w dont go in the same sentence... oh and make it easier on urself get a monobock amp. they are usually class d meaning more efficient
Old May 12, 2008 | 12:22 PM
Xenozx's Avatar
The type R is a Dual Voice Coil sub. That means I will need a mono block amp that can do 1 ohm stable right?
HOW DO YOU KNOW IF A AMP CAN DO 1 OHM STABLE, AS MOST ADVERTISE 4 and 2 ohm only
I was looking at this amp
http://cgi.ebay.com/NEW-2008-ORION-H...QQcmdZViewItem
since the type R is 1500w peak, that should be fine, even though they say the type R is 500 RMS>?
Old May 12, 2008 | 02:01 PM
warrenb213's Avatar
well, not if u got the dual 4 ohm type-r's.... then it'd lower to 2ohm.
Old May 12, 2008 | 02:12 PM
Xenozx's Avatar
I didnt even think of that! Thanks!
so if I did that, I could use a 2 ohm amp.
Now my question is, is there any sound difference when using 2 ohm vs 1 ohm. May be a stupid question but thought I would ask anyway
Old May 12, 2008 | 07:09 PM
blck2.4turbo's Avatar
more power outta da 1ohm but in most cases no need for the extra stress(sub/amp)
Old May 12, 2008 | 08:28 PM
Xenozx's Avatar
I went with
1 4ohm x 4ohm Type R 12
1 600w RMS Alpine @ 2 ohm
may be a little more wattage then the sub is spec'd for but I heard it shouldnt be a problem
2.0CF box tuned to 32 hz
Old May 12, 2008 | 08:41 PM
EmperorJJ1's Avatar
cool u should be fine.... a type r will handle 600w clean just fine clipping is what causes issues
Old May 12, 2008 | 09:29 PM
Xenozx's Avatar
The stock cobalt battery/alternator should be able to handle a 600w RMS sub without a cap right?
SmitBag
Sep 7, 2016 08:05 AM
Oct 20, 2015 09:56 PM
royce777
Sep 28, 2015 07:11 AM
dieGone
Sep 23, 2015 10:20 AM
n20saturn
Sep 21, 2015 01:50 AM
