4 ch amp RCA question
Old Aug 29, 2009 | 11:24 PM
brickloaf's Avatar
do i need to run 2 sets of rcas from the HU to the 4ch, one for rears and one for front speakers? seems like i would only need once since all 4 speakers were playing the same thing..
Old Aug 30, 2009 | 12:17 AM
InvisiBill's Avatar
Some (most?) 4-channel amps can run off a single set of RCAs for the source. If you want to use the fader on the head unit, you'll need to run separate RCAs for front and rear channels though.
Old Aug 30, 2009 | 02:31 AM
brickloaf's Avatar
thanks
Old Aug 30, 2009 | 05:32 AM
Spun's Avatar
The output power of the RCA's 2-5 volts usually is a huge factor in how well the amp preforms. If you have an amp that puts out 500 watts hooked up to a deck that only puts out 2 volts on the preouts its going to feel like your only getting 300 watts out of that amp.
When you use y adapters or runn all 4 channels off one set of preouts then you split the power of the RCA outs in half, and greatly reduce the power output of your amp
Old Aug 30, 2009 | 05:31 PM
brickloaf's Avatar
so i guess i shoudl go ahead and do 2 runs of rca, and my HU is 5volt
Old Aug 31, 2009 | 02:40 AM
EmperorJJ1's Avatar
yes if your hu has 3 preouts run all 3
Old Aug 31, 2009 | 03:11 AM
brickloaf's Avatar
emp whats the deal with the amp, i pm'd you 3-4 days ago and no response? maybe your box was full but a update would be nice
Old Aug 31, 2009 | 03:20 AM
EmperorJJ1's Avatar
hit me up on aim
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
c_m_shooter
Sep 27, 2015 04:40 PM
