4 gauge direct from alternator to Capacitor?
Sorry, I'm an idiot! However, you can tell me I'm wrong without telling me to f*** myself! I'm sorry it took so long to get through to me, but if someone had told me earlier that my alternator would explode if I did what was proposed, that would have been the end of it. In the end, I got the info I needed and won't be blowing up my alternator anytime soon! So thanks for the help.
My first goal was to teach you correct terminology so you could better understand WTF YOU were trying to do. How the **** could you expect me to understand it when you didn't even understand it enough to properly explain it?
The only thing in the back of my mind was "this dipshit has his cap wired in series because he thinks it's the right way to wire a cap."
I was trying to establish common ground (pun intended LOL) and you where still scattered wiring.
It's all good. Just try not to be so bone headed the next time someone tries to explain something to you and I'll try not to tell you to shove wire up your ass. Deal?
I was trying to tell you that in a round-about way, but I couldn't quite make out WTF you were trying to do because you kept using incorrect terminology.
Last edited by Bumpin Balt; Aug 3, 2007 at 12:26 PM. Reason: Automerged Doublepost
Adding a 4ga from the alternator to the cap (so you have 3 wires on the positive cap terminal, one from the batt, one from the alt, and one to the amps) would be essentially the same as adding another 4ga from the alternator to the battery, since everything is wired in parallel.
Wow! I wish you had been the first person to respond on this thread. That's more or less what I was trying to figure out! One guy said if I run a wire directly from the alt to the cap, I will short the alternator to ground and fry the alt, is that true? I would run the 4 gauge directly to the battery, but it's buried under a solid floor board and I don't think I have enough wire to reach that far. If this is the only safe way to wire my system, then I'll splurge and buy some 2 or 0 gauge and run it from alt to battery, as well as adding heavier ground wires. I was just looking for a possible alternative so I could use the 4 gauge that I already have and save some money in the process.
The place I think it would help the most would be from the capacitor to the amp. Try it and see. Just hold it there and see if it helps with whatever length you have now.
BTW, have you measured the amount of amperes running through your wire(s)? That will tell you a lot in itself.
I'm gonna tell you a quick story...
I had a '92 Camaro which had a JVC HU, an Alpine EQ (similar to yours), an Alpine 35w x 4 and a RF Punch 100 DSM (seriously under rated) running to two MTX 12" Thunder Series subs. I kept blowing 30 amp fuses like crazy. So I measured the amperes running through the 10 ft. long 4 gauge wire running to the RF amplifier.
58 amps!!! Talk about lights dimming at idle. They about shut off sometimes.
The stock alt. put out 85 amps and that was it. Figure in the amount of current to run the car itself (fuel pump, injectors, sensors, ignition, etc.) plus the marker lights, tail lights and headlights plus the 58 amps that amp was sucking and you can easily see I needed a higher output alt.
Measure yours. I'd be interested to see how many amperes it takes to run your system at full tilt.
Check out some of the info at this link. It has info on the resistance of wires and a voltage drop calculator at the bottom. You can play with the wire size and distance to see the drop. For example, if you're passing 50 amps through 10 feet of 4 ga wire at 12 volts, you will lose .255 volts. If you take the same scenario but use 2 ga wire, you'll lose .161 volts. 1/0ga will lose .101 volts.
Thanks AJ and bandit for taking the time to help me out, +1rep to both of you! My 2 farad cap came yesterday, so I installed it and performance has improved quite a bit. My sub hits harder and sound more accurate. I can't see the voltage when I'm driving, but it must be holding at a higher more consistant level.
Its not as simple as using a voltmeter since ammeters need to be wired in series with the main power cable. Obviously this is not possible with a regular multimeter since the leads are tiny.
So, what voltage reading are you getting at idle?
If you want to know what the voltage reading is while driving just have a friend rev up the engine to ~3,000 RPM and hold it there while you watch the voltage meter on the capacitor. It's the same difference, really.
If this truly fixed your problem that's great.
Godspeed.
Godspeed.
The clamp on DC ammeters are expensive. Here's one: http://www.powerstream.com/DC-clamp.htm
also im not sure my 2/0 wire can fit in that thing
