trunk latch rattle?
trunk latch rattle?
When my subs are on in my car, the only rattle i can hear from outside the trunk is right where it latches down. Is there anyway to fix that? is there just a loose bolt or something? does anyone else have this problem?
I'm curious, are you positive it's the trunk latch and not the air recirculation cap at the bottom right of the trunk? I had a cavalier with the same piece and after putting my sub in the Cobalt, it rattles like crazy and I've never figured out a way to properly secure it, while retaining a decent recirculation vent...
That's not a bad idea. When you sprayed foam in it, did you leave the plastic bracket in there and just seal the inside of it, or remove it completely? I'm a little concerned about removing given the battery could potentially be subject to water, but that rattle is both annoying and embarrassing as it happens on my Cobalt at the slightest volume of bass...
i left the bracket in there. i dont remember exactly how i did it but i tried to keep the foam inside the car as much as possible and it worked pretty well. i think i might have done layers idk, i just sprayed it on the braket itself sorta
