trunk latch rattle?
Old 09-30-2011, 08:18 PM
the jelly man's Avatar
trunk latch rattle?
When my subs are on in my car, the only rattle i can hear from outside the trunk is right where it latches down. Is there anyway to fix that? is there just a loose bolt or something? does anyone else have this problem?
Old 10-01-2011, 06:39 AM
EmperorJJ1's Avatar
you can try tighening it down but your probably going to need to put sound dampening on the trunk itself. idk how loud you are but i had that same issue and i got it to go away by putting dampening on the bumper itself
Old 10-01-2011, 11:01 AM
L7D4N's Avatar
I'm curious, are you positive it's the trunk latch and not the air recirculation cap at the bottom right of the trunk? I had a cavalier with the same piece and after putting my sub in the Cobalt, it rattles like crazy and I've never figured out a way to properly secure it, while retaining a decent recirculation vent...
Old 10-01-2011, 03:04 PM
EmperorJJ1's Avatar
oh the pressure vent? it could be that but that normally makes a distinct sound not quite a rattle
Old 10-01-2011, 03:23 PM
punksk8ter62's Avatar
I had subs in my cobalt but had to remove them. This car rattles so bad. The heat shields around the exhaust rattled on mine. Couldn't stand it. Lol
Old 10-01-2011, 03:32 PM
Stefan Groenhout's Avatar
the rattle i coming from right behind the lock. so it is either that or it is the trunk latch. those are the only two things i can think of
Old 10-01-2011, 03:35 PM
Could it possibly be the seat releases. I had a problem with those rattling as well.
Old 10-01-2011, 06:32 PM
L7D4N's Avatar
Yup, that's it.
Did you do anything with it, or leave it alone?
Old 10-01-2011, 07:02 PM
i didnt do anything with thr pressure thing. left it alone dodnt wanna mess with it.
Old 10-01-2011, 10:19 PM
EmperorJJ1's Avatar
Originally Posted by L7D4N
Yup, that's it.
well i got some expanding foam...
I never honestly herd mine thou. it was just one of those things ive already done everything else why not
Old 10-01-2011, 10:42 PM
drumrush's Avatar
if you turn it up loud enough you wont be able to hear any rattles
Old 10-02-2011, 01:11 AM
L7D4N's Avatar
That's not a bad idea. When you sprayed foam in it, did you leave the plastic bracket in there and just seal the inside of it, or remove it completely? I'm a little concerned about removing given the battery could potentially be subject to water, but that rattle is both annoying and embarrassing as it happens on my Cobalt at the slightest volume of bass...
Old 10-02-2011, 02:52 AM
EmperorJJ1's Avatar
i left the bracket in there. i dont remember exactly how i did it but i tried to keep the foam inside the car as much as possible and it worked pretty well. i think i might have done layers idk, i just sprayed it on the braket itself sorta
Old 10-08-2011, 12:46 PM
where did you put the foam at?
Old 10-08-2011, 01:09 PM
im confused on what bracket you are talking about.
Old 10-18-2011, 06:09 PM
Can i remove the black plastic piece that is covering the latch in the trunk? Maybe then i will be able to pinpoint the rattle?
Old 10-18-2011, 07:12 PM
EmperorJJ1's Avatar
yes you can. in fact that part hasnt been in my car for years
Old 10-18-2011, 07:37 PM
Dors it just pull up?
Old 10-19-2011, 07:43 PM
is it the four clips kind of on the bumper? or can i just pull up really hard and it will come up? kind of like everything else on the car?
Old 10-19-2011, 10:19 PM
EmperorJJ1's Avatar
ya just pull up
jimbofug007
10-02-2015 12:06 PM
grampss
09-27-2015 08:51 PM
c_m_shooter
09-27-2015 04:40 PM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: trunk latch rattle?
