Accessory Fuse?
Accessory Fuse?
Ok first off is there a fuse box on the drivers side of the dash under the radio??
i belive this is where someone told me to run my power for my aeroforce to by putting in an accesory fuse?
what does one of those fuses look like i went to autozone and couldnt find anything. I also havent popped off that panel yet, is there a fuse box behind it?
Thanks,
Ryan
Thanks,
Ryan
The Add a fuse would work. Another way to do it is if there is an empty place for a fuse and it has a contact test to see if it has power and see if it only has power when the key is in the on position and then get an inline fuse and put a blade connector on the end of it and push it into the contact.
brickloaf
Sep 25, 2015 09:10 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
