Accessory Fuse?
Old Mar 7, 2007 | 09:38 AM
CobaltBurst's Avatar
Accessory Fuse?
Ok first off is there a fuse box on the drivers side of the dash under the radio??
i belive this is where someone told me to run my power for my aeroforce to by putting in an accesory fuse?
what does one of those fuses look like i went to autozone and couldnt find anything. I also havent popped off that panel yet, is there a fuse box behind it?
Thanks,
Ryan
Old Mar 7, 2007 | 09:57 AM
origami78's Avatar
The Fuse box is on the passenger side. The cover is kind of hard to pull off but not to bad.
Old Mar 7, 2007 | 09:59 AM
alright cool what do accesory fuses look like? i guess they slide in like a fuse but you can wire accessories to them...?
Old Mar 7, 2007 | 10:04 AM
distillion's Avatar
its called add a fuse or something like that, listnening for more details, i have the dual areoforce i will be installing nextweek sometime hopefully.
Old Mar 7, 2007 | 10:18 AM
origami78's Avatar
The Add a fuse would work. Another way to do it is if there is an empty place for a fuse and it has a contact test to see if it has power and see if it only has power when the key is in the on position and then get an inline fuse and put a blade connector on the end of it and push it into the contact.
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
brickloaf
Sep 25, 2015 09:10 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
