Adding another Stock Sub?
Old Mar 11, 2007 | 09:59 PM
95cam86roc's Avatar
A friend of mine is giving me his stock sub out of his SS/SC. I was wondering if there was a way to hook it up. I figure that i will need an additional amp. But i was told by the local stereo shop that i wont be able to run the extra sub. If someone can help me out here i would greatly appreciate it.
Old Mar 11, 2007 | 10:06 PM
halfj99's Avatar
theirs always a way...my suggestion would be a line level output thing..that taps off your rear speakers wires...then run a wire from your wipers fuse upfront to the remote wire on the amp, that way it will only be on with the raido..then power/ground and run your speaker wires
it accually seems like a really cool idea to me accually...
Old Mar 11, 2007 | 10:14 PM
95cam86roc's Avatar
So it can be done. I didn't see why it couldn't but according to the stereo shop it couldn't. Do you think it will be hard to do? And should i get another amp?
Old Mar 11, 2007 | 11:34 PM
SS SCHGD's Avatar
only problem I see is that it's going to face the wrong way if you put it on the other side...don't know where else it would go.
After taking apart my own stock system, I don't see why you couldn't change out the subs to dual 4 ohm subs and split the signal from the stock factory one and run half to the other one....(the stock sub is dual 2ohm and each channel is run by the amp individually)
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
