Aem Gauge
Old Apr 9, 2008 | 06:31 PM
SS/SC Crazer's Avatar
Aem Gauge
OK, i have purchased the AEM UEGO air fuel gauge. however i can not find a pillar pod that it will fit in. i bought one from ZZP and it didn't fit, then i looked at Cobalt Addiction and it sais that their pod will fit this guage, well guess what, not even close. I opened the hole as big as i could get it with out taking off the side. so, does anyone know where i can get an A pillar triple gauge pod that is color matched and will fit the AEM UEGO air fuel gauge.
Old Apr 9, 2008 | 06:58 PM
ColeJJones's Avatar
Bannned
wtf, your stock pillar fits it perfect
Old Apr 9, 2008 | 08:41 PM
ya but i want to keep the boost gauge also
Old Apr 9, 2008 | 08:43 PM
95cam86roc's Avatar
My pod is from CA and my Uego doesn't fit either
Old Apr 9, 2008 | 08:47 PM
rico's Avatar
i got the tripple pod from zzp and it worked great
Old Apr 9, 2008 | 09:02 PM
ColeJJones's Avatar
Bannned
use the center pod that goes on your steering wheel
Old Apr 9, 2008 | 09:04 PM
Super_SS's Avatar
mine fits fine
https://www.cobaltss.net/gallery/fil...ulley_2445.jpg
Old Apr 9, 2008 | 09:05 PM
bigrroberto's Avatar
uh oh. Better fit, I just ordered the one off of CA too...
Old Apr 9, 2008 | 09:07 PM
95cam86roc's Avatar
if it does then you'll be lucky
Old Apr 9, 2008 | 09:10 PM
calchr2's Avatar
i have the autometer/guage works triple pillar pod and my autometer air fuel gauge fits in. unfortunaltly i dont have any pictures
Old Apr 9, 2008 | 09:17 PM
95cam86roc's Avatar
All the other gauges fit, just not the Uego
Old Apr 9, 2008 | 09:22 PM
ssmokin's Avatar
that wont work with the AEM. the bezel will hit the steering wheel when you turn. he would have to move his boost gauge to the steering column pod and put the AEM in the stock a pillar.
Old Apr 9, 2008 | 09:24 PM
how come everyone says it will. Even the product says it fits a standard guage pod ?
Old Apr 9, 2008 | 09:32 PM
95cam86roc's Avatar
i dunno ask the vendor. Both mine n my friends Uego's do not fit. And that was with even sanding down the inside of the opening to allow for more room. The thing is the Uego has to be a bit bigger than the stock boost gauge bc the stock boost gauge fit fine in every hole.
Old Apr 9, 2008 | 09:35 PM
M-Dub's Avatar
The AEM uego is actually just a smidge bigger than the standard gauge.. you just need to dremel or cut it out just a little bit to make it fit snug!
Old Apr 9, 2008 | 09:36 PM
haha will do. I'll make er' fit
Old Apr 9, 2008 | 09:39 PM
stealthy1ss's Avatar
The back part of the UEGO is the same size as the stock boost gauge. (2 1/16") The reason why it has fitment issues is because of the bezel. I just took my dremel to the gauge pod and opened it up enough to get in there but it doesn't fit flush like my boost and interceptor gauge. Also I believe that the aftermarket gauge pods are ever so slightly smaller than the stock one.
Old Apr 9, 2008 | 09:42 PM
95cam86roc's Avatar
thanks for the help dub
Old Apr 9, 2008 | 09:46 PM
Z Speed's Avatar
hmmm... looks like I will have fun tryin to get my wideband to fit in my zzp pillar pod
Old Apr 9, 2008 | 10:11 PM
I filed the hole as big as i can make it, there is no more room with out cutting intothe side. the actual screw on face doesn't fit in the area they provided.
Originally Posted by Super_SS
What did u do to get it to fit?
Last edited by SS/SC Crazer; Apr 9, 2008 at 10:11 PM. Reason: Automerged Doublepost
Old Apr 10, 2008 | 06:01 PM
rico's Avatar
mine fit just fine
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
