AeroForce Kills battery
Old Jul 11, 2011 | 02:40 PM
DarkChild's Avatar
I hooked my AeroForce gauge and it killed my battery. I lead the red wire to an ACC and the left the other two because they aren't "needed" to be used. I was just temporarily trying it out while I wait for my gauge. Could anyone help me so that it won't kill my battery thanks.
Old Jul 11, 2011 | 03:09 PM
Godly's Avatar
I'd just splice into your boost gauges power wire for the red (power) cable coming from the interceptor.
Which IDK if that will work, since in the LNF all you have to do is plug it into the OBDII port for them to work
Old Jul 11, 2011 | 05:00 PM
DarkChild's Avatar
I did that. I didn't use the Boost gauge ACC wire but I used the radio ACC wire. When you open the door it should turn off. I also need to re-route the ground to my UEGO. When it is hooked up it makes a high pitch sound through my speakers at a low volume. I don't like to have it turned up all the time. Thank you.
Old Jul 11, 2011 | 05:22 PM
Godly's Avatar
Hmm, im at a loss man. Wish I could help.
Just FYI though, my interceptors stay on after I shut the car down, lock it and everything for about a minute after exiting the car.
Old Jul 11, 2011 | 09:18 PM
DarkChild's Avatar
That's exactly what mine does. I think it is getting power through the OBD2 port. I will email them personally.
Old Jul 11, 2011 | 09:33 PM
07BoostedG5's Avatar
If you read the interceptors instructions (not to sound like an ass) it states some cars have power going constantly thru there port and if thats the case they say unplug it if you do not drive the car for more then 5 days
Old Jul 12, 2011 | 03:35 AM
EmperorJJ1's Avatar
uh there is no radio acc wire
Old Jul 12, 2011 | 11:41 AM
DarkChild's Avatar
Mine died after a day. I use my car daily. I understand if I were to park it. I didn't know that though, thank you
Yes there is. I have an aftermarket indash dvd player. In the kit is a wire you lead... you put that wire to a fuse that uses the ACC through the ignition.
Old Jul 12, 2011 | 12:51 PM
EmperorJJ1's Avatar
so you ran the acc to the fusebox. which fuse did you tap?
Old Jul 12, 2011 | 07:48 PM
sLAsh's Avatar
Your interceptor is obviously broken. You should just sell it to me for $13.49 shipped and you won't have to worry about your battery anymore
Old Jul 12, 2011 | 07:51 PM
blake05SS's Avatar
did u take the little red clip off the back? mine is going to my boost gauge and it wouldnt shut off until i pulled the tiny red clip off the back
Old Jul 12, 2011 | 08:06 PM
Omnigear's Avatar
hook the power where there is only power when the ign key is on. the radio can still turn on with the key on the acc.
Old Jul 12, 2011 | 08:12 PM
blake05SS's Avatar
just splice into ur boost gauge/end thread
Old Jul 13, 2011 | 09:46 PM
DarkChild's Avatar
Oh, I see Blake05SS. Thank you. I didn't take it out because I thought it was to connect to another interceptor. I will do that.
Old Jul 14, 2011 | 08:48 AM
blake05SS's Avatar
ya i did the same thing but once u take the clip off it will shut off when u turn ur key off
Old Jul 14, 2011 | 10:51 PM
DarkChild's Avatar
I just want to you thank you for your help. It was the solution.
\thread
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
