Aftermarket Install FAQ
Old Jun 19, 2008 | 05:41 PM
Gotenks's Avatar
Originally Posted by YellowSS06
X2!! I have everything hooked up the way it's supposed to be, but have absolutely no sound at all!!!
the blue/white wire gets hooked up to the blue wire....
The other blue one can be capped off
Old Jun 19, 2008 | 05:44 PM
YellowSS06's Avatar
Yep, that's what I ended up doing, when I hadn't heard anything back. I figured the power antenna might send the signal as a remote. Works like a dream now.
Old Jul 5, 2008 | 11:56 PM
streetracinazian's Avatar
[QUOTE=zinner;1522500]Since it's coming up a lot I have created this thread to consolidate all the findings from after market installs on the cobalt.
No the Avic-D3 is too deep to fit in the existing radio well. You have to remove some of the plastic behind the radio and bend some supports back. Also I trimmed the front bezel in the 95-3302 kit and redrill some screw holes for the Avic to sit forward a bit more in the mount.
There are lots of wires to hook up. The VSS is tapped off the C3 pin 45 yellow wire off the PCM in my 05 SS/SC, when you hook it up it takes about 5 miles for it to begin to pick up the VSS as a simple hybrid, so don't be worried if it doesn't work right away.
i'm getting this headunit pretty soon,what plastics do i have to remove and what supports get bent, as well as the trimming of the bezel kit? anything major cuz i'm doing htis myself, i'm kinda discouraged now?
as well as VSS, this is the wire you tap into so dvd can be used right? i've been into audio for a while, but nav and dvd are a new department for me. any help would be greatly appreciated!
Old Jul 6, 2008 | 12:55 AM
EmperorJJ1's Avatar
vss wire is for gps
Old Jul 6, 2008 | 01:06 AM
thanks bro! so i tap in to vss wire for gps, how do i go about doing the dvd bypass? gosh, i'm scared outa my minds to do this headunit now.
Old Jul 6, 2008 | 04:31 AM
EmperorJJ1's Avatar
u need a switch
Old Jul 6, 2008 | 04:39 AM
aight 2 down, not so bad from what i'm getting. as stated the avic-d3 is too deep and stuff needs to be trimmed and what not, what exactly get's trimmed and all that stuff? it won't be to hard will it?
Old Jul 6, 2008 | 05:21 PM
TeDy's Avatar
Hahahahaha
I'm sorry.... But if you're going to cut away at that stuff yourself... Just say "Hi" to the bracket from hell for me.
Old Jul 7, 2008 | 01:59 AM
? i've had some tuff situations, hopefully this one won't be the one that shoots me in the foot.
Old Jul 8, 2008 | 09:44 PM
polocobalt's Avatar
i want to install a aftermaket radio but bestbuy said i need a special part for my 07 ls model. How can i get this radio install ?
Old Jul 11, 2008 | 01:38 AM
  #36
scottyguy401's Avatar
Alright so I just got done installing everything for my avic d3 except one thing. The antenna. In the op zinner mentioned that you hook up the blue antenna wire to the blue amp on wire. I don't have the wiring harness he used. I have the gmos lan04 since I have a 07 balt. How do I go about hooking up my antenna. I quicky found out the antenna that goes to the stock radio will not fit in the avic d3 since it is some crazy antenna.
Old Jul 24, 2008 | 05:35 PM
  #37
Dispute's Avatar
Im looking for the vss, I used the grey wire pin 61, and it dosnt work at all. where is the yellow one? I looked under the hood in front of the fuses and there are two connector things. Is the wire in one of those?
Old Mar 28, 2009 | 12:17 AM
  #38
SS SCHGD's Avatar
Can someone give a picture or a better idea of where the C3 connector is that I need to use for VSS? (and Reverse too?) thanks.
Old May 4, 2009 | 09:58 AM
  #39
V8Huntr's Avatar
Sorry to revive an old thread but I've been reading about the VSS signal wire and there seems to be a lot of confusion. Has anyone tried to tap it off of the back of the gauge cluster? When I installed my Eclipse AVN 5510 in my old car I just tapped it off of a signal wire on the back of the gauge cluster and it worked perfectly.
Old May 13, 2009 | 08:25 PM
  #40
OneCOLDBIZL272's Avatar
can some one help me out i have my avic installed and theres not sound everything else is working i heard something about a remote wire but where is it and what wire does it go to. some please help?
Old May 14, 2009 | 01:41 AM
  #41
EmperorJJ1's Avatar
replied in ur thread
Old Apr 22, 2010 | 08:00 PM
  #42
chucklowe44's Avatar
just so ya'll know the gm lan-4 will solve most of the stereo wiring issues. it keeps onstar and all the chimes. there is another adapter at the website that will allow you to keep most of the steering wheel controls too.
http://www.installer.com/item/displa...it=GMOS-LAN-04
Old Jun 10, 2012 | 05:15 PM
  #43
Drunkship's Avatar
Does anyone know how much juice the stock amp for the Pioneer system pushes? I'm thinking about replacing the subwoofer with another 10" and don't want to replace the stock amplifier because of the convenience.
Old Jun 11, 2012 | 12:28 AM
  #44
EmperorJJ1's Avatar
i belive it was rated at 350w peak. so 175rms or 117 rms depending on how shady pioneer is or isnt. then divide that into the 7 speakers which shouldn't be even. its hard to say but in the past i think ive bet high at 75w rms for the sub. if u give them the benefit of the doubt of 175 this might go up to 100 at best
Old Jun 11, 2012 | 12:31 AM
  #45
EmperorJJ1's Avatar
oh and just to add i think replacing just the sub no amp is a bad idea
Old Jun 11, 2012 | 09:06 AM
  #46
Drunkship's Avatar
Thanks for the info. The Pioneer system isn't too bad. Just wanna see how I can add a little OOMPH to it the easiest and cheapest way possible. Maybe I'll look into just replacing the stock speakers.
Old Jun 11, 2012 | 11:30 AM
  #47
EmperorJJ1's Avatar
mm problem with that is ud have to look into 2 ohm speakers.
Old Jun 11, 2012 | 12:15 PM
  #48
Drunkship's Avatar
Thanks, I knew you were the one to ask. Had no clue the Pioneer system was wired up at 2 Ohms. Time to do some research.
Old Jul 5, 2012 | 05:16 PM
  #49
Chrisbrown08LS's Avatar
I have a 2008 cobalt LS what do I need to have in order to put an aftermarket stereo in
Old Jul 6, 2012 | 03:05 AM
  #50
EmperorJJ1's Avatar
https://www.cobaltss.net/forums/elec...aq-read-96094/
