Aftermarket radio ignition
Old Jan 23, 2018 | 06:07 PM
Danny harsh's Avatar
I installed an aftermarket radio into my SS and I'm having an issue with the radio turning on with the ignition and turning off when the car is shut down.. I have to manually turn the radio on and off if that makes more since.. Any ideas?
Old Jan 23, 2018 | 10:55 PM
cluelessk's Avatar
Did you use a wiring harness or wire it yourself?
It sounds like you have the switched wire hooked up to a constant source.
Old Jan 24, 2018 | 04:28 PM
I did use a wiring harness. I guess I will have to go back through all my wiring and double check everything.
Unique Crysis
Oct 17, 2013 05:11 PM
pdub
Feb 15, 2011 04:35 PM
CobaltLs_14
Dec 21, 2009 04:58 PM
IanWilson2007
Feb 29, 2008 07:45 AM
tattoodNruderacing
Jan 7, 2007 07:02 PM
