Aftermarket wiring harness?!?!
Old Dec 23, 2006 | 11:24 PM
theboy16's Avatar
I have bought 3 different hiring harnesses, the one best buy sold me wont even fit, the other ones fit but my radio wont turn on. What brand, model number, and where did you get yours?
Old Dec 23, 2006 | 11:26 PM
The_Blur's Avatar
Scosche GM13B (2005 Cobalt)
Old Dec 23, 2006 | 11:33 PM
theboy16's Avatar
isnt there anything besides that
Old Dec 23, 2006 | 11:38 PM
DWK5150's Avatar
Did you run the power wire?
Old Dec 23, 2006 | 11:40 PM
Xavipheus's Avatar
Did you run the red wire to your fuse box? Also do you have an 05-06 or an 07?
Old Dec 23, 2006 | 11:50 PM
theboy16's Avatar
wires were matched up to the to the harnesses. how can i make one of the fitting harnesses work
Old Dec 23, 2006 | 11:57 PM
Xavipheus's Avatar
You could try reading our questions
Old Dec 24, 2006 | 12:03 AM
theboy16's Avatar
sorry 06 nothing was run to the fuse box or power supply. my next door neighbor knows a lot about car audio, he told me just to match up wires on the harnesses that is what i did. i matched the colors
The_Blur's Avatar
I had my buddy install it. I'm not messing around with GM's crazy wiring.
Old Dec 24, 2006 | 12:06 AM
theboy16's Avatar
the yellow power wire was connected to the yellow power wire
the black ground wire was connected to the black ground wire
and the red signal wire was connected to the red signal wire
Old Dec 24, 2006 | 12:11 AM
The_Blur's Avatar
You know what I mean. Late-model GM cars have some craptastic wiring. The harness is a bitch, some areas are too tight, and some wires are not where they usually are in other cars. Technicians do not like GM cars.
Old Dec 24, 2006 | 12:15 AM
Xavipheus's Avatar
The red wire is the ACC wire, it needs to be tapped to something that is only powered on by accessory (this way the head unit knows when to be on and when to be off) You can use a fuse tap and tap the sunroof or an empty fuse in the box. Until you do this, your head unit wont work and or will drain your battery till its dead.
Old Dec 24, 2006 | 11:11 PM
theboy16's Avatar
i am re-pinning my harness
which wires go in the slots
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
