alarm wire question
Old Jan 28, 2010 | 06:44 PM
Rydis's Avatar
alarm wire question/trigger sensor (negative)
I am trying to install and DEI audio sensor. Since I dont have a DEI system, I need to wire the alarm to the stock alarm in my 06 SS. I have looked at the diagram..but I am having trouble figuring out which wire I need to tap into. I am looking for a Instant trigger sensor input.
Old Jan 30, 2010 | 10:57 AM
Rydis's Avatar
No one?? I would assume even any aftermarket alarm would require the same wire??
Old Feb 9, 2010 | 04:52 PM
Rydis's Avatar
bump still looking
Old Feb 14, 2010 | 11:10 AM
Rydis's Avatar
ok I give up
Old Feb 15, 2010 | 04:49 PM
Rydis's Avatar
http://www.alertautomotive.com/diagrams/diagrams.asp
found this with some more searching..but for the alarm/disarm it doesn't list any wires..just uses remote key. I guess im looking for the negative wire that sets off the alarm.
Old Feb 16, 2010 | 10:55 AM
ptrblkz24's Avatar
Diode isolate the wire and tap into one of The door trigger wires that turn the dome light on.u also have to wire the sensor into a wire that switches to ground when u shut the car off(to turn the sensor on) because the sensor will trigger the dome light on and off while ur driving. I know the ignition wire switches to ground when u turn the car off,but it might burn out ur sensor when it reads 12v when u start the car.
Old Feb 16, 2010 | 06:21 PM
Rydis's Avatar
not sure what a diode isolation is but ill look it up. Sensor says its rated for 12V so I think hooking it in with my stereo should be fine. Good to know I am getting somewhere with this lol thanks!
Old Feb 22, 2010 | 07:16 AM
Rydis's Avatar
Well I messed around with it this weekend and it seems to be working but with a slight problem. My Door is triggering every few seconds now. Will do the 3 chimes and say Door Ajar and looks will engage constantly while driving. Any idea on what might be causing this?
I have a 2door so I only had the Grey/Black and Tan/White Wire (though I had 2 tan/whites I used a voltmeter to test which was the door trigger). I wired the 2 diodes up to the door triggers then wired them to my alarm wire.
I know the diodes have to be in correct so should be preventing feedback. I know they are in the correct way because I followed a diagram and the alarm wasn't working (because the diagram showed the diodes going the wrong way), I then turned them and it started working fine (diode polarity faces towards teh device).
I rechecked to make sure the connections were good, and they are. So any idea what is causing my door trigger to constatly trigger? (maybe diode to small..its 50V - 1A..pretty sure while driving my car isn't constaly putting out over 50V...)
Thanks!
Edit: Seems anything that would set off my alarm is triggering this problem. Dont see how since I have the diodes there..but I guess I can just unhook it while driving..
Old Feb 22, 2010 | 08:05 PM
ptrblkz24's Avatar
What sensor do u have?506t?
Old Feb 22, 2010 | 10:21 PM
Rydis's Avatar
Yes Sir
Old Feb 24, 2010 | 04:17 PM
Rydis's Avatar
I think its just being overly sensitive (even on the lowest setting my ebrake clicking will set it off). Guess I should invest in something better.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
