Alpine amp and sub
Old Oct 10, 2010 | 03:19 PM
balt_ls's Avatar
Oh how it feels to be a
Alpine amp and sub
So Just Curious if anyone is running an Alpine SWR-1242D 12" Type-R With an Alpine Mrp-m500. If so what do you have your gain and bass eq set at. I just bought both brand new.
Old Oct 11, 2010 | 03:42 AM
EmperorJJ1's Avatar
gain depends on the radio and bass eq should be all the way off
Old Oct 11, 2010 | 07:47 AM
^^this, but the bass is your opinion, depends on what you want (hence your sub and amp) its easy to adjust, sit in the drivers seat crank it up and tweek with it
Old Oct 11, 2010 | 08:08 AM
balt_ls's Avatar
I have a clarion hundred and it has 6 volt pre outs.
Old Oct 11, 2010 | 10:25 AM
EmperorJJ1's Avatar
this one?
Clarion U.S.A. | CZ100
Old Oct 11, 2010 | 10:46 AM
balt_ls's Avatar
This one
Clarion U.S.A. | DXZ675USB
Old Oct 11, 2010 | 10:50 AM
Maupin SS/SC's Avatar
Begin jack/ did u tell me the static from my stereo was part of the whole stock amp bs? /thread jack
Old Oct 11, 2010 | 10:56 AM
Cefaln452's Avatar
if you have an oscilloscope or rta near by you can figure it out perfectly....or if you know what to listen for you can do it by ear.
clarion radios usually dont distort till max volume... thats the slide track radio and is true for that... so you can go to 32 or 33 with no problem and have it on plus 6 for sub... make sure you have dze 3, and the other potions flat
Old Oct 11, 2010 | 08:53 PM
EmperorJJ1's Avatar
id try it at say 1/4 gain and see how it sounds
Old Oct 11, 2010 | 08:54 PM
EmperorJJ1's Avatar
possibly... what static are u talking about
Old Oct 11, 2010 | 09:01 PM
balt_ls's Avatar
Well thanks. i set it a little bit higher than 1/4.
And how can you stop screws from coming out of the box? LOL. I kept hearing the noise that sounded like the sub was bottoming out or something and finally was able to turn it up and be able to see what was goin on and the front of box and top had screws coming loose. How can i fix this?
Old Oct 11, 2010 | 09:10 PM
Cefaln452's Avatar
use bigger thread screws, or get an mdf box
Old Oct 11, 2010 | 09:35 PM
balt_ls's Avatar
Is an mdf box made by me 3 or 4 years ago.
Old Oct 11, 2010 | 10:27 PM
EmperorJJ1's Avatar
is it bare wood atm? if the screws tight and the box is still holding up well then cover the tops with bondo or glue or something. possibly something on the bottom too
Old Oct 11, 2010 | 10:45 PM
balt_ls's Avatar
Yea its bare wood. I was thinking about spreading something over top of the screws or pulling the screws out and squirting some wood glue in the holes and rescrew them.
Old Oct 11, 2010 | 10:49 PM
EmperorJJ1's Avatar
id say yank glue then spread something on top... might as well do them all
Old Oct 11, 2010 | 11:10 PM
when the volume is down...
Old Oct 11, 2010 | 11:11 PM
balt_ls's Avatar
Yea i think i will definatly.
Quit thread jacking
HAHAHA just ******* with you.
But i have the same noise through my speakers.
Old Oct 11, 2010 | 11:25 PM
my car is loud so its gone when the engines on
Old Oct 11, 2010 | 11:28 PM
EmperorJJ1's Avatar
ya thats stock amp awesomeness for you. you can try a ground loop isolator but in general not much you can do
balt_ls's Avatar
Mines gone once i plug in the phone and turn it up. HAHAHA
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Turbo6
Aug 27, 2015 08:37 PM
iwantacobalt
Oct 29, 2005 03:31 PM
