Amp Mounting?
Amp Mounting?
For those that mounted an aftermarket amp to the back of the rear seats what kind of screws did you use? wood, or sheet metal, or something else? And is it holding on pretty solid? I noticed that the back of the rear seats seems like it is a plastic behind the carpet and did not know if it would hold up well.
So the amp should be pretty secure using the screws that came with it. I just wanted to check what everyone one else was using.
Thanks everyone, I will use the screws that came with the amp.
someone here has there amp set up either under the carpet on the decklid in the car or in the trunk mounted to the metal decklid i cant rember. either way it lokke pretty call up out of the way and no wires it was all tucked
n20saturn
Sep 30, 2015 12:26 AM
