Amp Overheating...
Amp Overheating...
Ok I Have a Pheniox Digital 1000W amp With a 1F AudioBahn Cap and one 12" AW1251T AudioBahn Sub. Now My Amp OVer Heats After About 10 mins of use, unless i have rear windows down. I believe CC installed a 1200 Watt amp kit. Could That be the reason. Just making sure. if So ima just buy a new amp and eventually 12W7 :P.
umm
what size wire are you using?
is the amp wired with too low resistance for the subs?
do you have a good ground, and clean power?
if you dont know what you're doing, why are you buying a 12w7??
Mmmm 12w7... very very worth the money.
Also, make sure that all your wire connections including the speakers are making good contact. I had a loose wire on one of he voice coils and it sent it into pretection mode.
