Amp wont power on! :(
Old Jan 18, 2008 | 07:29 PM
hosal's Avatar
My amp to my alpine type e will not power on! I don't know what's wrong, i checked all the wires a ton of times and still nothing. It's a JL amp almost brand new what the **** is going on damnit. Can anyone help?
Old Jan 18, 2008 | 07:44 PM
bgbearcatfan's Avatar
sounds like a problem with your pcont wire. Did you test all the lines to make sure you getting power signal with each? are you using an aftermarket hu?
Old Jan 18, 2008 | 08:17 PM
EmperorJJ1's Avatar
test the remote wire for 12+ or 14v... test the power for 12+ or 14v
Old Jan 18, 2008 | 11:56 PM
hosal's Avatar
how do i test?
Old Jan 19, 2008 | 12:16 AM
with a voltmeter
where are you getting your remote turn on wire from?
Last edited by bgbearcatfan; Jan 19, 2008 at 12:16 AM. Reason: Automerged Doublepost
Old Jan 19, 2008 | 12:26 AM
hosal's Avatar
i'm not sure i had a shop hook it up?
Old Jan 19, 2008 | 12:30 AM
Sarbae's Avatar
so it was working before?
Old Jan 19, 2008 | 01:04 AM
Spun's Avatar
Sounds like you just blew a fuse, could be the one right at your batt. or the one on the amp itself. If you had it done at a shop then take it back to them tell them to fix it, but after they do take it somewhere else and have hem look it over, if your blowing fuses for no reason then your a) drawing to much power and need to up the size of the fuse (this of course does not count for the amp fuse) or b) shoddy install, which could be a number of probles (wires are exposed to metal being the most common) . There is one more thing, some decks have a fuse on the remote wire, its only a 0.5 amp one but it could have blown as well .
When you opened your trunk did it smell like burnt plastic/rubber or was there any foul order in the air, it would still be there as burnt curcitry tends to linger
Old Jan 19, 2008 | 01:58 AM
Sarbae's Avatar
My thoughts exactly. That's why I asked if it had been working before. Anything else not working?
Old Jan 19, 2008 | 04:53 AM
EmperorJJ1's Avatar
eh take it back to the shop and save ur self the trouble... make sure they dont charge u
Old Jan 19, 2008 | 08:31 AM
hosal's Avatar
They have the amp kit hooked up to the fuse box where the + red is at. The fuse is not blown on that, i'm not sure if the remote fuse is blown or not. But it was working for about a week. It's a JL amp. I check the ground wire and it was working fine. Only thing i can think of is the remote wire behind the stock headunit.
Old Jan 19, 2008 | 03:48 PM
EmperorJJ1's Avatar
there is no such remote wire on the stock hu hence running the remote wire to the fuse box
Old Jan 21, 2008 | 10:08 AM
hosal's Avatar
then what could be causing this?
Old Jan 21, 2008 | 10:11 AM
DarkCobalt13's Avatar
are there fuses on the amp itself? My Kenwood does and its blown those 2 times now
Old Jan 21, 2008 | 10:38 AM
EmperorJJ1's Avatar
amp could be blown, the ohm rating of the speakers is below what the amp is "stable" at so its not happy, one of those wires could be shorting causing low voltage and making the amp not turn on (either power or remote), bad ground, blown fuses on amp or power wire
Old Jan 22, 2008 | 02:09 PM
Spun's Avatar
Turn your gain down, shorten your ground and get thicker wires.
If your blowing fuses its because your drawing too much power
Old Jan 22, 2008 | 07:55 PM
wordsthatiwrote's Avatar
Next thing i can think of is to check the fuse box for the 15A mini fuse. If that is not blown, Unplug the headunit and the wireharness and plug it all back in. I had to do that for my car. I just installed a NEW headunit with a GMOS-LAN-04 and they amps were not turning on so i disconnected the harness and reconnected it and everything is functional now.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
