Antenna Cable Help!
Old Aug 12, 2011 | 11:28 AM
gooty4life71290's Avatar
Antenna Cable Help!
Long story short my gf's cobalt antenna cable got cut and then after i tried to resolder it and fix it didnt fully work, so i went to the dealership and got the replacement cable which is def long enough to go from the antenna to the radio
replacement part is # 22736115
only problem is that both ends are female and the one side has the "wings" on it which i know goes to the antenna and that plugs right in. the other side however had a plastic mounting pressure pin on it that made me think it plugs into some sort of junction box. On the stock cable the end that works with the radio is a male end so i am thinking since it came with that mounting bracket piece and its the wrong connector then there must be somewhere that it plugs into a junction of some sort...i already called best buy and the installer said the same thing and i should check around the glove box and passenger side dash...
here is the clip that came mounted on the one end
i tried following the wire last night but was pretty tired and gave up lol...all i know is that it joins up with a large coil of wires and works it way towards the glove box so ANY HELP WOULD BE GREAT!
Old Aug 12, 2011 | 07:29 PM
c4w18's Avatar
2006 cobalt for me and no junction box in my car.....goes from the antenna to the extension cable directly into the radio....sorry i can't help you there, but i've never seen a junction box on the balts i've worked on, maybe emperorJJ could tell you whats up....
If it were me, I'd just drop a few bucks on a male to male extension.....if you have a stock radio, you'd need the reverse antenna adapter and another male to male extension piece.
Old Aug 12, 2011 | 09:46 PM
its an aftermarket deck and i already have the correct antenna adapter so it looks like ill end up buying a male to male antenna connector and see where that gets me thanks for the input !
bump for anymore input!
Old Aug 13, 2011 | 03:24 AM
EmperorJJ1's Avatar
oh **** i might have remembered pop off the side panel by the glove box (the black piece that would touch the door panel) i think its there
Old Aug 14, 2011 | 10:44 AM
okay thanks a bunch fellas because when i looked at it i was like huh? and that mounting clip really threw me off, will let you know how i make it out later when she gets outta work and i car look at her car...
Old Aug 14, 2011 | 12:39 PM
c4w18's Avatar
no problem buddy let me know how it goes
Old Aug 14, 2011 | 03:59 PM
so my gf got to my house finally and i went out and did some more investigating and i took the passenger side panel at the end of the dash to glance inside and try and follow the cable and sure enough there was a connection with that pressure pin...for anyone who needs with this in the future i took pictures lol
thanks for all the help!
Old Aug 15, 2011 | 02:02 AM
thanks a bunch!
Old Dec 20, 2012 | 09:28 PM
wol-shiver's Avatar
Question, sorry to revive an old thread.
what path does the cables use? does it go over the roof liner, through c pillar to a pillar? or under carpet along the right side?
do you still have the pics, i cannot find this junction.
Old Dec 21, 2012 | 03:23 AM
EmperorJJ1's Avatar
its under the carpet on the right side.
unfort i dont have pics but its under these dash pieces (right side parts not the fusebox ones)
they touch this lil indention in the door
Old Dec 21, 2012 | 11:15 AM
wol-shiver's Avatar
Sorry EMp, you keep responding to me, thank you so much!
i am more interested in the route of the cable from the back.
i broke ym cable and bought a new one and need to pull it out.
i know it runs through the quarter panel over the wheel well, but i lose sight of it after that.
Old Dec 22, 2012 | 03:10 AM
EmperorJJ1's Avatar
it goes thru the opening just under the rear deck and pretty much shoots straight to the antenna /bracket. its taped up in with a bunch of wires so sorta hard to trace
chefhhr
Oct 26, 2015 10:36 PM
footballplaya3k
Sep 30, 2015 09:39 PM
dieGone
Sep 23, 2015 10:20 AM
