anti-theft
Old Feb 28, 2021 | 10:35 PM
Kevin Valerio's Avatar
anti-theft
So while out of town,a neighborhood lowlife tried to steal my 08 colt lt with auto trans.
I discovered the column torn apart. I figured out where everything went and put it all back together except
the actual ignition switch was damaged. The actual switch not the lock cylinder.
So I ordered a new on and installed it.
I can not get out of theft mode. I have tried the 10 min switch on 10sec switch off. dont work.
dash icon is said to blink after 10 min. but mine dont.
I have tried this about 30 times seriously. Also tried the door lock hold key 30 second method. Dont work.
all fuses are good. Battery 12.5 v
HELP PLEASE SOMEONE!!
Old Mar 1, 2021 | 01:36 PM
You're going to have to take it to a dealer, they'll confirm all the wiring is correct and will likely need the Tech2 and GM codes to program everything correctly.
Old May 11, 2021 | 07:48 AM
With all due respect Mr. Ecaulk,
I would sooner die and go to hell.
Old May 11, 2021 | 09:04 AM
Well then enjoy the paperweight, from your description no one online can help.
The attempted theft has likely triggered an theft reaction in the anti-theft and potentially locked the system down, knowing GM it likely cannot be reset without a tech2 and probably some GM code only dealers have access to.
Old May 11, 2021 | 09:28 AM
Kolt's Avatar
Yea, its unfortunate but your gonna have to bring it into a dealer man. I'm a tech at a dealer and once the theft has been tripped (and you have also replaced the ign switch which on most requires the same procedure) the immobilizer system is going to have to be reset/reprogrammed using our sps program (service programming system). Honestly they are also going to need to recheck the column wiring, theft module, and also the circuits to the ign switch, bcm, and theft module to make sure nothing was damaged that a untrained eye wouldn't be able to spot. Something as simple as a terminal slightly backed out of a connector or spread when they were trying to hot wire it would brick the car. Could have also blown some fuses for the ign switch, bcm, and theft module. Too many things that could go wrong very easily when theft attempts are made. I know bc I've had to fix a lot of them, and its always easier and cheaper when the cust hasn't tried to fix it themselves bc that can hide problems we would have been able to spot when it was torn apart by the thief's.
Old May 11, 2021 | 10:41 AM
Thank you for the reply and enlightenment. I have done some research thus making myself especially
dangerous. So far I have determined it is a passkey 111+ system.
I've seen methods for bypassing'. I don't want it fixed.I want it gone,
These procedures are common for after market remote starters.
I suppose what I really am asking is guidance on getting rid of it all together.
Old May 11, 2021 | 10:51 AM
BlackielawlessSS's Avatar
GM really made it difficult. They knew they would make money on it.
Old May 12, 2021 | 10:32 AM
Kolt's Avatar
From what I currently know there isnt a bypass for the 08+ security. I know hp tuners can disable it on certain 07 and down ecms but i do not know of any workarounds on 08+. If there is one you would likely end up spending more money and time to do that than it would be just to get it fixed.
Old May 12, 2021 | 11:37 AM
ProfDNS's Avatar
I mean, this is vandalism, so your insurance may cover this as the dash was ripped apart, or if it's a write-off; take that money and find yourself an SS
Old May 12, 2021 | 04:00 PM
Kolt's Avatar
I would guess they have liability only, it is only a cobalt ya know , we are the only ones with enough lack of sense to have full coverage on ours.
Old May 12, 2021 | 04:29 PM
ProfDNS's Avatar
Right?
Although I also drive on one of the most busiest highways in North America, so that's my excuse.
Old May 12, 2021 | 04:42 PM
There was this thing GM did called the my key and or ignition switch falls out. Worked great for the anti theft.
Old May 12, 2021 | 09:08 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
A looooong time ago (early to mid 90's), my dad had an early 80's Chevy C10. You could definitely pull the key out of the ignition while it was running... and it'd keep on running.
TR6
Nov 26, 2019 11:30 AM
perogers56
Jun 11, 2017 10:15 PM
05Slowbalt
Sep 16, 2011 06:38 AM
strykr
Aug 19, 2011 03:44 PM
bluebalt
Jun 22, 2006 11:51 PM
