Anyone Remove Door Speakers yet?
Old Mar 7, 2007 | 03:27 PM
BooSSted's Avatar
I am going to be swaping out the speakers in the front doors in the next couple of days. Has anyone done this yet? Anything I should know or look out for before I do it? Hints?
Old Mar 7, 2007 | 03:53 PM
show off's Avatar
if you didnt get the premium sound system, get a dremel. youll have to cut off the old speaker and screw the new on onto its plastic mounting ring.... thats about it.
Old Mar 7, 2007 | 04:05 PM
xspyder85x's Avatar
its not too hard, ive done it about 10 times. i recommend getting a speaker baffle from crutchfield though.
Old Mar 7, 2007 | 05:32 PM
BooSSted's Avatar
Ugh, I hate those baffles. Your refering to the cup that goes inside the door right?
Old Mar 7, 2007 | 05:35 PM
italstalnprd86's Avatar
the speaker will get rusty and **** if you dont use them, pick up some foam ones on ebay, I got them, they were pretty cheap
Old Mar 7, 2007 | 06:00 PM
mind4engineering's Avatar
what are you talking about??? i replaced mine without cutting anything except wires...
Old Mar 7, 2007 | 09:51 PM
mesatrin's Avatar
On the non-premium systems the speakers have an odd shaped plastic addapter (the premium system may have this too I don't know). The opening is shaped more like a 5x7 than a 6.5.
Old Mar 7, 2007 | 10:02 PM
show off's Avatar
the premium system doesnt have them, its a whole different door panel.
if i can find some pics, ill show you
Old Mar 7, 2007 | 10:05 PM
bryce712's Avatar
just make sure you dont brake your door handle or itll suck trying to get in and out.
Old Mar 7, 2007 | 10:08 PM
yellowshowbalt's Avatar
what they r the same ive done both the only difference is the wiring plugin
Old Mar 8, 2007 | 12:03 AM
alpollon's Avatar
i hate them too, thats why i just take a foam one and cut it in half and use it as a hat if you will for the speaker, to keep water off it but keeping the airspace the same
Old Mar 22, 2007 | 02:49 PM
sunrise_mj's Avatar
yeeeaaa... go to homedepot. buy a small sheet of 1/4" MDF... make a template, done... that way you can go back to factory later on when selling...
Old Mar 24, 2007 | 12:44 AM
SS SCHGD's Avatar
My Base stereo Cobalt had the plastic attached to the Speaker, I screwed my 6.5"s to the door (with 3 screws) and no problems. The premium system in the SS had a plastic adapter that came off the speaker, I kept them for use with the new 6.5's and it worked ok, keeps the speaker from hitting the window and gives me 4 points to screw too. When I do My SS, my 6.5's are bigger (magnet size) then the other ones, so i will need to make a plate out of MDF.
By the way, why do we use MDF and not a HDF board?
Old Mar 24, 2007 | 12:49 AM
ted5986's Avatar
i just grabbed a piece of 3/4 mdf i had laying around from a previous build adn cut it to size. i have never had a problem with rusting...ever.
Old Mar 24, 2007 | 02:26 AM
yellow2003xtreme's Avatar
I made baffles for my Camaro to put 6.5's in place of the 6X9's...didn't even think of doing that on the Cobalt.
I just drilled 2 holes and mounted the speakers that way.
Old Mar 24, 2007 | 02:33 AM
bigrroberto's Avatar
mdf is cheaper
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
xxenjoi11
Sep 29, 2015 12:36 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
