pioneer sound system
Old Mar 23, 2007 | 05:01 PM
superchargedCMG123's Avatar
Question pioneer sound system
i recently bought a 2006 cobalt ss supercharged and i have a couple questions about the pioneer system..
first off, does anyone know the wattage output of the pioneer subwoofer? and also has anyone tried putting in another amp to power the subwoofer? i expected the sub to hit harder and i thought it just might not be getting enough power from the amp that the cobalt comes with.
any extra information involving your own enhancements to the sound system would also be appreciated.
thanks
Old Mar 23, 2007 | 05:04 PM
devon9832's Avatar
Well i replaced my stock with a pioneer avic z1. I believe when you change out the stock one you always get a better hit. However, everything else is stock except for the headunit and with a few setting changes, the subwoofer sounds like a 15 inch....sounds good.
Old Mar 23, 2007 | 05:08 PM
05REDROCKET's Avatar
The whole system is 228 Watts. The amp runs more then just the sub, if you want a louder thump get a new ampand new sub. The factory Pioneer sub can't pound without popping, but it depends how loud do you want it?
Old Mar 23, 2007 | 05:17 PM
devon9832's Avatar
i don't believe that because like i stated above, i switched out the head unit and when i play a song with a hard bass note at play it loud....it handles it clearly...soooo i think the pioneer sub is greeeeeaattttt
Old Mar 23, 2007 | 09:23 PM
roccobladr's Avatar
any problems swithcing out the stock head unit when you got the pioneer system? (im a complete n00b with car stereo)
Old Mar 24, 2007 | 05:25 AM
EmperorJJ1's Avatar
if you have xm (and want to keep it) or onstar i wouldnt even try honestly but if you dont have either then its not bad
about the stock sub idea you can do alot of things to enhance the sound and pretty much anything you upgrade will help... and your best/loudest sound will come from doing them all
an aftermarket sub is usually more efficient so just changing that should get you more thump but very limited
an aftermarket amp will get you the power you need/want but since the stocker is realativly low powered you may blow it with too much power
an aftermarket hu will provide extra cleaner power to bump up the sound on the whole system and can offer better control of the sub to make it sound better.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
