audio jack
Old Jan 7, 2011 | 01:07 PM
deereboy4320's Avatar
audio jack
is it possible to install a audio jack into a stereo with out the pioneer and without onstar?
Old Jan 7, 2011 | 01:25 PM
hawlyns711's Avatar
yes I believe so, it will take a bit of work though. if your cobalt is anything like my redline I needed to buy the XM brain and wire that in to the stock deck, and then I just spliced up my aux in (ipod) through the xm inputs.
Old Jan 7, 2011 | 05:04 PM
would it just be easier to buy the xm radio out of a coblat for that year
Old Jan 10, 2011 | 10:47 AM
hawlyns711's Avatar
well not sure there. my redline didn't come with xm at all, but the factory head unit comes all set to accept the xm. so I just added the xm. so in other words, your head unit probably already has xm capabilities you would just need the other hardware (antenna, xm brain, wiring)
Old Jan 10, 2011 | 10:51 AM
myfakeevo's Avatar
there was a guy who tapped into xm radio wire to make an audio jack. so find the wires that use xm radio, then tap into it, switch to xm every time you want to use the audio jack and it will play music
Old Jan 10, 2011 | 11:03 AM
hawlyns711's Avatar
exactly what this guy said, but you of course need the additional xm hardware first.
Old Jan 10, 2011 | 12:16 PM
denlou's Avatar
He doesn't need the XM hardware, he just needs to take the car to the dealership to turn the XM capability on in the headunit itself; He doesn't need the XM receiver hardware, just turn the XM input on in the head unit.
Old Jan 10, 2011 | 01:39 PM
hawlyns711's Avatar
hmm, I think you may be mistaken, unless you know something I don't. but from what I can tell in the schematics there is a GMLAN that goes from the xm module to the radio and on this low speed LAN is a signal voltage which tells the head unit that there is an available input on that aux port. this is what enables XM on the unit. unless I'm wrong here?
Old Jan 10, 2011 | 01:51 PM
denlou's Avatar
hahaha oh...
Ugh, I guess we better figure out what year the OP's car is.
Old Jan 10, 2011 | 02:34 PM
hahaha oh...
2006 ls
Old Jan 10, 2011 | 03:27 PM
denlou's Avatar
Originally Posted by deereboy4320
2006 ls
Alright, then check out this thread...
https://www.cobaltss.net/forums/how-...obalts-184854/
Then the only additional step you'd have to do since you don't have XM is take your car to a dealership (or anybody with a Tech2 tool), and have them activate the XM input on your head unit. You don't need the XM receiver itself for this to work.
Oh and I guess I should add, you'll only be able to enable XM if you have the "Band" and "Src" buttons on your stereo.
agentirons
Oct 16, 2015 02:11 AM
Turbo6
Sep 24, 2015 04:15 PM
Cptnslo
Sep 24, 2015 09:32 AM
Builttss
Sep 21, 2015 04:29 PM
