AVH P3100DVD Questions
Old May 7, 2010 | 08:33 PM
nouseforaname's Avatar
Alright.. I'm goings to be installing my new head unit this weekend, and I just have a few quick questions to ask before I go and mess something up.
First of all, what should I do with the parking brake wire? Should that just be grounded in order to bypass the whole 'You can't watch videos while driving' thing?
Second, what does the 'Reverse gear input signal' connect to? Or should I say.. what should I connect it to.
Lastly, what the hell is the 'mute' wire for?
Thanks!
Old May 7, 2010 | 11:27 PM
TommyP's Avatar
AWD > FWD
Ground the parking brake wire to whatever, but wire a switch. The easy way to bypass that unit is to turn a switched ground on and off. Unless you are hooking up a backup camera, you can just ignore the reverse wire. IDK about the mute wire
Old May 8, 2010 | 12:26 AM
EmperorJJ1's Avatar
ignore the mute as well. if you got the module harness follow its instructions
Old May 8, 2010 | 08:36 PM
Thanks, guys! I put it in and it works great BUT...
I couldn't find anything in the fuse box to tap into for the ACC power wire that actually comes on when the key is in the ACC position. (I have a base model.. there is no sunroof fuse etc)
I ended up tapping into the wiper fuse which comes on when the key is in the 'Start' position. However.. I would like to have it come on with the key in the ACC position. What could I tap into in the fuse box since I have a car with no sunroof, power windows, etc?
Old May 8, 2010 | 08:54 PM
iboost's Avatar
What I think you can try is the rear defogger. I think that comes on in 'acc' position. Also you can't just ground that parking brake wire for the video to work. It needs to see a change which is why the switch thing works. I have this unit installed in my girls VW Tiguan. I used a relay that I got from Autozone and wired it up...now I can watch the vids and what not
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
