BCM question
BCM question
Okay its actually two. First where is the BCM3 for the '08 base models. Two I need to attach a wire to the A10 wire for dome light supervision. Which wire is A10?
thanks!
thanks!
thanks
I need to attach a wire so that the alarm can detect when the dome light comes on. If this isnt the best way, can someone on here who has installed alarms on our cars tell me where to attach the dome light supervision wire?
Its in C3 and its grey
Here is a pin-out of the BCM
Its way down there but if you scroll down you will see it
Body Control Module (BCM) C1
Pin
Wire Color
Circuit No.
Function
L-BU/BK
747
Left Rear Door Ajar Switch Signal (Sedan)
Not Used
PU
5531
Hood Closed switch Signal
TN/BK
109
Hood Ajar Switch Signal
Not Used
WH
682
Door Lock Lock/Unlock Signal
WH
682
WH
1080
Park Lamp Relay Control
9-12
Not Used
13
PK
849
Brake Fluid Level Sensor Signal
14
L-BU
1134
Park Brake Switch Signal
YE
5199
Run/Crank Relay Coil Control
WH
193
Rear Defog Relay Control
17
D-BU
Right Front Turn Signal Lamp Supply Voltage
18
D-GN
5060
Low Speed GMLAN Serial Data
19
TN/WH
746
Right Front Door Ajar Switch Signal
20
L-GN/BK
748
Right Rear Door Ajar Switch Signal (Sedan)
Not Used
22
GY/BK
745
Left Front Door Ajar Switch Signal
23-25
Not Used
26
L-GN
1478
Coolant Level Switch Signal (LSJ)
27-32
Not Used
D-GN/WH
1135
A/T Shift Lock Control Solenoid Supply Voltage (MN5/MX0)
34
Not Used
35
L-BU
14
Left Front Turn Signal Lamp Supply Voltage
36
D-GN
5060
37-43
Not Used
44
TN/WH
1969
Headlamp High Beam Relay Control
45-46
Not Used
47
YE
196
Windshield Wiper Motor Park Switch Signal
48-50
Not Used
51
D-GN
113
Windshield Wiper Switch Signal
52-53
Not Used
54
YE
317
Fog Lamp Relay Control (T37)
55
OG/BK
744
Rear Compartment Lid Ajar Switch Signal
56
OG/BK
737
Rear Compartment Lamp Control
57
BN
253
Trunk Release Relay Control
58-59
Not Used
60
TN
28
Horn Relay Control
61
BK/WH
1251
Ground
62
RD/WH
1240
Battery Positive Voltage
63
GY
596
5-Volt Reference - 1
64
BK/WH
751
Ground
65
TN/WH
1704
Low Reference
66
GY/BK
1798
Low Reference (Sedan)
67
YE/BK
61
Low Reference
68
WH
5075
Current Sensor Signal
69
Not Used
70
D-GN/WH
636
Ambient Air Temperature Sensor Signal
71
L-GN/BK
592
DRL Relay Control
72
Not Used
Body Control Module (BCM) C2
Pin
Wire Color
Circuit No.
Function
BN/WH
2500
High Speed GMLAN Serial Data (+)
TN/BK
2500
YE
Headlamp Switch Signal
PU
524
Headlamp Dimmer Switch High Beam Signal
BN/WH
301
Park Lamp Switch On Signal
6-8
Not Used
WH
111
Hazard Switch Signal
TN
1576
Rear Compartment Lid Release Switch
D-GN
264
Security Indicator Supply Voltage
12-13
Not Used
14
TN
28
Horn Relay Control
WH
103
Headlamp Switch Headlamps On Signal
OG
192
Front Fog Lamp Switch Signal (T37)
17
PU/WH
549
Headlamp Switch Headlamps Off Signal
18
Not Used
19
BN
2501
High Speed GMLAN Serial Data (-)
20
TN
2501
21-25
Not Used
26
D-GN
44
Instrument Panel Lamp Dimmer Switch Signal
27-37
Not Used
38
D-GN
5060
39-43
Not Used
44
L-GN/BK
1137
DRL Ambient Light Sensor Signal
45-46
Not Used
47
YE/BK
1138
DRL Ambient Light Sensor Low Reference
48-50
Not Used
51
BN
1356
Flash To Pass Switch Signal
52-53
Not Used
54
L-BU
20
Stop Lamp Supply Voltage
55
Not Used
56
WH
1390
Off/Run/Crank Voltage
57
GY
112
58
PU
719
Low Reference
59-60
Not Used
61
GY
1884
Cruise Control Switch Signal (K34)
62
WH/BK
1073
Ignition Key Resistor Signal
63-65
Not Used
66
YE/BK
1418
Left Rear Turn Signal Switch Signal
67
D-GN/WH
1419
Right Rear Turn Signal Switch Signal
68
L-BU
292
Rear Defog Switch Signal
69
L-GN
66
A/C Request Signal (C67)
70
Not Used
71
PU
5234
Passenger Seatbelt Reminder
72
WH
193
Body Control Module (BCM) C3
Pin
Wire Color
Circuit No.
Function
A1
TN
294
Door Lock Actuator Unlock Control (AU3)
A2
TN
294
Door Lock Actuator Unlock Control (AU3) (Sedan)
TN
294
A3
D-BU/WH
149
Courtesy Lamp Supply Voltage
A4
GY
295
Door Lock Actuator Lock Control (AU3) (Driver)
GY
295
Door Lock Actuator Lock Control (AU3) (Passenger)
A5
GY
295
Door Lock Actuator Lock Control (AU3) (Sedan)
GY
295
A6
Not Used
A7
BN
Park Lamp Supply Voltage
A8
PK
339
Run/Crank Ignition 1 Voltage (UQ3)
A9
YE
18
Left Rear Stop/Turn Lamp Supply Voltage
A10
GY
157
Courtesy Lamp Control
A11
Not Used
A12
D-GN
19
Right Rear Stop/Turn Lamp Supply Voltage
B1
TN
694
Driver Door Lock Actuator Unlock Control
B2
Not Used
B3
RD/WH
1240
RD/WH
1240
B4
Not Used
B5
BN
Accessory Voltage
BN
Accessory Voltage (L61/LE5)
B6-B7
Not Available
B8-B11
Not Used
B12
GY
Instrument Panel Lamp Supply Voltage (LSJ) and (J41)
B12
GY
Instrument Panel Lamp Supply Voltage (L61/LE5)
GY
C1-C2
Not Available
C3
D-GN
1301
Retained Accessory Power Fuse Supply Voltage
C4
Not Used
C5
D-GN
801
C6-C7
Not Available
C8-C11
Not Used
C12
OG
228
Windshield Washer Pump Control
D1
RD/BK
142
D2
Not Available
D3
Not Used
D4
RD/WH
840
D5
D-GN
801
D6
PK
739
D7
PK
1339
Ignition 1 Voltage
D8-D9
Not Used
D10
RD/BK
442
D11
Not Used
D12
RD/WH
242
Body Control Module (BCM) C4
Pin
Wire Color
Circuit No.
Function
A1
RD/WH
640
Battery Positive Voltage (UQ3)
A2-A12
Not Used
B1
OG
228
B2
GY
B3-B12
Not Used
C1
RD/WH
1440
C2
GY
GY
C3-C5
Not Used
C6-C7
Not Available
C8
BN
Accessory Voltage
C9-C10
Not Used
C11
GY
C12
GY
D1
RD/WH
1040
D2
Not Used
D3
YE
5199
Run/Crank Voltage
D4
BN
141
Ignition3 Voltage
D5
Not Used
D6-D7
Not Available
D8-D9
Not Used
D10
RD/WH
1140
RD/WH
1140
D11-D12
Not Used
E1
RD/WH
140
E2-E5
Not Used
E6
PK
439
Ignition1 Voltage
PK
439
Ignition1 Voltage (Coupe) (TV5)
E7-E11
Not Used
E12
BK/WH
651
Ground
F1
RD/WH
1540
RD/WH
1540
F2
Not Used
F3
GY
GY
F4
PK
339
Ignition1 Voltage
PK
339
Ignition1 Voltage
F5
PK
339
Ignition1 Voltage
PK
339
Ignition1 Voltage
F6
PK
339
Ignition1 Voltage
F7-F8
Not Used
F9
PK
1539
Ignition1 Voltage
PK
1539
Ignition1 Voltage
F10-F12
Not Used
Pin
Wire Color
Circuit No.
Function
L-BU/BK
747
Not Used
PU
5531
TN/BK
109
Not Used
WH
682
WH
682
WH
1080
9-12
Not Used
13
PK
849
14
L-BU
1134
YE
5199
WH
193
17
D-BU
18
D-GN
5060
19
TN/WH
746
20
L-GN/BK
748
Not Used
22
GY/BK
745
23-25
Not Used
26
L-GN
1478
27-32
Not Used
D-GN/WH
1135
34
Not Used
35
L-BU
14
36
D-GN
5060
37-43
Not Used
44
TN/WH
1969
45-46
Not Used
47
YE
196
48-50
Not Used
51
D-GN
113
52-53
Not Used
54
YE
317
55
OG/BK
744
56
OG/BK
737
57
BN
253
58-59
Not Used
60
TN
28
Horn Relay Control
61
BK/WH
1251
Ground
62
RD/WH
1240
63
GY
596
64
BK/WH
751
Ground
65
TN/WH
1704
Low Reference
66
GY/BK
1798
67
YE/BK
61
Low Reference
68
WH
5075
69
Not Used
70
D-GN/WH
636
71
L-GN/BK
592
DRL Relay Control
72
Not Used
Pin
Wire Color
Circuit No.
Function
BN/WH
2500
TN/BK
2500
YE
PU
524
BN/WH
301
6-8
Not Used
WH
111
TN
1576
D-GN
264
12-13
Not Used
14
TN
28
Horn Relay Control
WH
103
OG
192
17
PU/WH
549
18
Not Used
19
BN
2501
20
TN
2501
21-25
Not Used
26
D-GN
44
27-37
Not Used
38
D-GN
5060
39-43
Not Used
44
L-GN/BK
1137
45-46
Not Used
47
YE/BK
1138
48-50
Not Used
51
BN
1356
52-53
Not Used
54
L-BU
20
55
Not Used
56
WH
1390
57
GY
112
58
PU
719
Low Reference
59-60
Not Used
61
GY
1884
62
WH/BK
1073
63-65
Not Used
66
YE/BK
1418
67
D-GN/WH
1419
68
L-BU
292
69
L-GN
66
70
Not Used
71
PU
5234
72
WH
193
Pin
Wire Color
Circuit No.
Function
A1
TN
294
A2
TN
294
TN
294
A3
D-BU/WH
149
A4
GY
295
GY
295
A5
GY
295
GY
295
A6
Not Used
A7
BN
A8
PK
339
A9
YE
18
A10
GY
157
A11
Not Used
A12
D-GN
19
B1
TN
694
B2
Not Used
B3
RD/WH
1240
RD/WH
1240
B4
Not Used
B5
BN
Accessory Voltage
BN
B6-B7
Not Available
B8-B11
Not Used
B12
GY
B12
GY
GY
C1-C2
Not Available
C3
D-GN
1301
C4
Not Used
C5
D-GN
801
C6-C7
Not Available
C8-C11
Not Used
C12
OG
228
D1
RD/BK
142
D2
Not Available
D3
Not Used
D4
RD/WH
840
D5
D-GN
801
D6
PK
739
D7
PK
1339
Ignition 1 Voltage
D8-D9
Not Used
D10
RD/BK
442
D11
Not Used
D12
RD/WH
242
Pin
Wire Color
Circuit No.
Function
A1
RD/WH
640
A2-A12
Not Used
B1
OG
228
B2
GY
B3-B12
Not Used
C1
RD/WH
1440
C2
GY
GY
C3-C5
Not Used
C6-C7
Not Available
C8
BN
Accessory Voltage
C9-C10
Not Used
C11
GY
C12
GY
D1
RD/WH
1040
D2
Not Used
D3
YE
5199
Run/Crank Voltage
D4
BN
141
Ignition3 Voltage
D5
Not Used
D6-D7
Not Available
D8-D9
Not Used
D10
RD/WH
1140
RD/WH
1140
D11-D12
Not Used
E1
RD/WH
140
E2-E5
Not Used
E6
PK
439
Ignition1 Voltage
PK
439
E7-E11
Not Used
E12
BK/WH
651
Ground
F1
RD/WH
1540
RD/WH
1540
F2
Not Used
F3
GY
GY
F4
PK
339
Ignition1 Voltage
PK
339
Ignition1 Voltage
F5
PK
339
Ignition1 Voltage
PK
339
Ignition1 Voltage
F6
PK
339
Ignition1 Voltage
F7-F8
Not Used
F9
PK
1539
Ignition1 Voltage
PK
1539
Ignition1 Voltage
F10-F12
Not Used
Iceberg
Sep 29, 2015 12:33 PM
