Best Way to Seal a Box
Old Aug 17, 2011 | 12:27 AM
09-cobalt-lt's Avatar
So I've been building my sub box myself and I got it all done. The only problem is that I just used the wood glue from putting it together to seal it and when I turned my sub on it totally broke the glue. What do you guys use to seal your boxes properly? Thanks in advance
Here's the setup basically done
Old Aug 17, 2011 | 12:38 AM
rephrase's Avatar
Predrill some holes, apply wood glue and shoot screws into it. Once it's dried use caulking around every edge, it'll be air tight.
Old Aug 17, 2011 | 12:39 AM
ted5986's Avatar
silicone.. run a nice bead around the entire inside of the box and make sure to hit the corners. push it in with your finger and let it cure for 24 hours with sub not mounted in the box.
Old Aug 17, 2011 | 12:44 AM
paintballerr78's Avatar
repharse basically said it....Put down some silicone and then clamp it closed and then screw the box together on all four corners... itll be air tight how i always built my boxes
Old Aug 17, 2011 | 12:45 AM
ben_gary's Avatar
Carpenter's glue then pre-drilling screw holes and screw (2in drywall screws) together then use silicon caulk on the inside
Old Aug 17, 2011 | 12:48 AM
07BoostedG5's Avatar
Liquid nails on the joints as with screws and caulk the edges with liquid nails, thats how we do it in the shop.
Old Aug 17, 2011 | 02:38 AM
EmperorJJ1's Avatar
liquid nails sealed much better then wood glue. wood glue is stronger in the end but with mdf and staples/screws it will be strong enough. If ur setup is done i would fiberglass the inside of the box single layer of the mat not cloth and just enough resin
Old Aug 18, 2011 | 06:21 AM
Ccadet02's Avatar
Use a router to carve grooves were you want all your wood pannals to go ie. sides, top, front, back....... Use liquid nails and clamp it down, pre drill and screw. Do not but the back part on untill u use silicone to seal the inside front. then but the back on and glue and screw then calk. this is by far the best way of doing it.
Old Aug 18, 2011 | 07:58 AM
HKnoma's Avatar
+3 Liquid Nails, use that stuff for everything
Old Aug 18, 2011 | 02:03 PM
thanks for the advice. I got it all sealed up yesterday. gonna stick the sub back in today and see how it turned out
Old Aug 19, 2011 | 05:15 AM
EmperorJJ1's Avatar
how did u do it?
Old Aug 29, 2011 | 03:42 AM
Just used some basic silicone caulking. It worked perfectly and there's no issues yet
Old Aug 29, 2011 | 10:51 AM
freakta's Avatar
best way to seal a box - feed it drinks hahahaha
sorry diff box
Old Aug 29, 2011 | 09:10 PM
c4w18's Avatar
Did anyone else misread this title and think it said "best way to steal a box"? Because I had a lot of good ideas until I realized the true title.
Old Aug 29, 2011 | 09:31 PM
EmperorJJ1's Avatar
man u just brought up some bad memories of a car that got jacked outside our shop. owner was stupid but it had a 15 and a 4cu ported box in an older car with a non folding seat with the X brace. they drilled out the lock but that didnt work so they pried up the trunk on both sides to try and get it open and that didnt work so they destroyed the back seat to see the brace, cut the right side of the brace folded it over and finally got it out. Yet for the amp they didn't cut the wires they unscrewed them all
Old Aug 30, 2011 | 10:53 PM
c4w18's Avatar
LOL wow that is some HOOD ****....worst we've had is someone drive off from our bay after running into the bay after stealing the work order.....he got caught tho cause the tech wrote down the plates and has a photographic memory....our boss pussed out tho, said pay me 2x the ticket amount and i'll let you go...I would've hung his ass personally....almost threw my kleins at his windshield when he wouldn't stop after we told him to....
Old Aug 30, 2011 | 10:58 PM
nhanson's Avatar
with your d-ick...then d-ick in a box!
Old Aug 30, 2011 | 11:35 PM
EmperorJJ1's Avatar
lol **** that throw some cheap tools instead
Old Aug 30, 2011 | 11:36 PM
c4w18's Avatar
yo those things are beasts though, I've had them since I used to do HVAC instead of car audio......It was about to be some patriot **** on his car for real....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Sep 28, 2015 02:46 PM
c_m_shooter
Sep 27, 2015 04:40 PM
