is big 3 necessary
Old May 25, 2009 | 09:58 PM
brickloaf's Avatar
is big 3 necessary
is it needed for 1500rms, i bought the all the wire about a month ago but its going to cost 150 to install and im broke at the moment...and i have a friend asking to buy it since hes going to need power wire for his new amp....?
sooo should I just get it installed or just ditch it....i have a yellow top btw if that matters
Old May 26, 2009 | 12:20 AM
EmperorJJ1's Avatar
if u need the money sell the wires to ur friend. It will help but cash is the key here. just do the battery negative use 4" (or whatever) of wire and sell the rest to your friend for however much you paid for it (or more whatever). then you get the 1 that does the most done and make ur money back. win win situation
Old May 26, 2009 | 12:43 AM
brickloaf's Avatar
i acctually did the ground one right when i got the wire...but yea ill probably sell it to him, ive only got 23 feet left but that should be more than enough for a regular car (with battery under the hood)
Old May 26, 2009 | 12:46 AM
EmperorJJ1's Avatar
17ft is a good estimate for power wire so that leaves enough for ground and everything.
Old May 26, 2009 | 03:32 AM
Spun's Avatar
Brickloaf!!!
Its just running wires.
All that is required is a little effort.
Pull the trim off the drivers side, pull the drivers side seat out and pull the back seat out. Peal back the carpet, find and or make a hole in the firewall, run the wire, tape it down,
Your Done, a couple hours tops.
What I'm getting at is you should just do it yourself.
Old May 26, 2009 | 09:02 PM
brickloaf's Avatar
i dont even know where the alternator is, and it would be a bitch to take out the seats and drill holes in the firewall.
Old May 26, 2009 | 11:00 PM
EmperorJJ1's Avatar
ah man i forgot to upload the pic. Either way there's a gigantic grommet on the driverside right by the gas pedal. i have both my power wires going thru there and could easily fit a third
and you know i can explain step by step how to do it if you wanted... But i know many people dont want to **** with it so i ultimatly could careless if you do it or pay a shop. Plus im putting someone else out of buisness so
Old May 27, 2009 | 01:35 PM
brickloaf's Avatar
i have a lt btw incase u didnt know, i think my alt is like on the bottom under the engine
Old May 27, 2009 | 08:06 PM
Spun's Avatar
You can get away with just the fuse box to the battery for now, then have someone else do the fuse box to alt and the the alt ground.
You just need to twist off the jumper post and then put the ring terminal (from the 0 guage) under the post when you screw it back on. Then piggy back it with the stock wire back to the battery (make sure the battery is disconnected when you do this of course).
Thats taking alot of the work out of it for someone else to do. Then if you pre make up the wires and have them get under the car to connect them to the alt it would only be a 10 min job (give or take).
Old May 27, 2009 | 08:30 PM
brickloaf's Avatar
what do you mean by piggyback the stock wire?
Old May 27, 2009 | 10:32 PM
EmperorJJ1's Avatar
i believe he means follow it. but the grommet it goes thru is a bitch to get to and its tapped up pretty good. I would just use the grommet above. assuming its the same in ur car (should be)
Last edited by EmperorJJ1; May 27, 2009 at 10:32 PM. Reason: Automerged Doublepost
Old May 27, 2009 | 10:53 PM
brickloaf's Avatar
im gunna give this a try tomorrow since tomorrow is like my car day. i have to strip my tint off, then get it retinted. try this, and after a month of waiting, i FINALLY GET MY L7's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 27, 2009 | 10:57 PM
Jplaya023's Avatar
hahaha my '06 2.4L has the battery in the trunk....lucky for me
Old May 27, 2009 | 11:01 PM
EmperorJJ1's Avatar
ya we all have batteries in the trunk
im sorry let me specify we all have a battery in the trunk, everyone else here (brickloaf, spun and I) has batteries in the trunk
Last edited by EmperorJJ1; May 27, 2009 at 11:22 PM. Reason: Automerged Doublepost
Old May 27, 2009 | 11:03 PM
brickloaf's Avatar
im sorry let me specify we all have a battery in the trunk me and spun are the only one with batteries in the trunk
and brickloaf
Old May 27, 2009 | 11:19 PM
EmperorJJ1's Avatar
did you finally get that second batt in?
Old May 27, 2009 | 11:27 PM
brickloaf's Avatar
yea 2 yellows now
o and btw idk if i told you but with the 20sq ft of damp pro i only got the spare well, a little on the lid, like 1 piece on the deck lid and i covered the back part of the trunk under the lid. ill prob order a door pack soon and that should be enough to cover like 85-90%
Old May 28, 2009 | 02:30 AM
EmperorJJ1's Avatar
sorta sounds familar but i dont memmer
Old May 28, 2009 | 02:41 AM
brickloaf's Avatar
spun
i tried what you said but im gunna have to leave it to the pros.
i saw the terminals on the fuse box, but i coudlnt see where they went. i looked by the pedals and couldnt find the power wire, and i would have to take out like EVERYTHING except the passanger seat to route the wire to the trunk
Old May 28, 2009 | 03:39 AM
EmperorJJ1's Avatar
**** following the stock wire thats stupid unless u plan on taking the car apart (and i know u dont). hey ill take some pics for u when i run my some more wires if ud like. its not that difficult if you use the grommet i have pictured. you cant see or get to the stock wire easily in any way shape or form. It took me a few hours to swap that bullshit out and i know exactly how to do it. I seriously put it off for a few months simply bc i knew it would suck. and it did
Old May 28, 2009 | 03:46 AM
Killa SS's Avatar
Im not a big audio guy. but im curious as to wut the big 3 exactly does and helps with. Im thinking of doing this just because im putting a system in my car but i dk wut i want yet. so if some one could plz explain. thx. and also, where the big three are located. size of wire. etc. etc. thx
Old May 28, 2009 | 03:55 AM
brickloaf's Avatar
i wouldnt really worry about it unless your putting a big system in...
but its basically upgrading the wire from the alternator to battery, battery to ground, and chassis to ground with 0g wire instead of the stock 4g
EmperorJJ1's Avatar
big 3 is bumping up 3 main wires in your electrical system BUT us cobalts have pretty decent wire stock so the effects are less then some older cars.
but the 3 wires are battery to ground, battery to alternator, alternator ground(engine ground is sometimes thrown in too). spun is the only one i know that has done it completely. ive done like 1.5
Old May 28, 2009 | 03:58 AM
brickloaf's Avatar
to run the wire from fuse box to battery did you have to take out any engine componets or did it just take forever to get around everything
Old May 28, 2009 | 04:02 AM
Killa SS's Avatar
ok. thx fellas. would i be upgrading the pos and neg wires on the engine bay fuse box as well?
