Blown speaker?
Old Mar 2, 2010 | 02:04 AM
SS SCHGD's Avatar
Blown speaker?
So I have not had much experience with blown speakers, as I do a good job matching equipment. I have a right front speaker that goes in and out on occasion, usually when it goes out, if I turn the volume up a good bit, it comes back on. Is this likely a Blown speaker? I have checked all connections and they are tight. (Other options are a bad channel on the amp, or a bad RCA Cable or output channel on the Head unit.)
Any ideas?
Thanks.
Old Mar 3, 2010 | 01:49 AM
EmperorJJ1's Avatar
check the tinsil leads on the speaker either wise its an rca or something like that
Old Mar 3, 2010 | 01:52 AM
silver187666's Avatar
mine did it to, depending on the weather they worked. i took them to the dealer to get replaced. best bet is to get some new ones
Old Mar 3, 2010 | 11:09 PM
SS SCHGD's Avatar
I have a basic Electonic meter, any way to Test them to know for sure? And when you say check the tinsil leads on the speaker, what am I looking for in particular? just loose?
I am about ready for new speakers and Amps, but would like to put them off for a bit.
Old Mar 4, 2010 | 01:35 AM
EmperorJJ1's Avatar
if you have a digital multi meter set it to ohms and test the speaker wires at the amp (with them out) should read somewhere around 4 ohms
when i say look at the tinsil leads u will probably need the speaker out but push the speaker out and see what happens. if it looks like something is breaking on the leads then thats the problem
oh do u have a high pass filter? whats it set at?
Old Mar 4, 2010 | 02:35 AM
SS SCHGD's Avatar
my high pass on the headunit is set to 180hz I think. the Amp High pass is set to somewhere around 200hz, and the Speakers are a set of Diamond D6 components, with a crossover, but I don't know what its set at. I will take the meter to them though. Thanks.
Old Mar 4, 2010 | 02:48 AM
EmperorJJ1's Avatar
sounds good i was going to say if u didnt have one set then broken tinsil leads on the speakers is much more probable (before i knew as much as i do know i went thru 4-5 rf FNQ 6.5s for that exact same reason)
test the wires and see what happens... you may have to do it at the crossover or the speakers themselves. now that i think of it im pretty sure testing with a passive crossover inline messes up the impedance. you may also have to pull out the speaker to actually look and play with it
Old Mar 4, 2010 | 11:39 PM
SS SCHGD's Avatar
ok, well taking a drive to Florida on Sat. will have to deal with it for a week, but then I can take a better look at them. I was thinking about taking a Infinity kappa (perfect? refrence? which ever is the best one Infinity makes are in the cav) pair out of the Cavalier and transporting them in the cobalt.
xxenjoi11
Sep 29, 2015 12:36 PM
ThoR294
Sep 28, 2015 05:31 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
