Bluetooth Question
Old Oct 14, 2014 | 07:57 PM
Gixxercobaltdriver's Avatar
Bluetooth Question
Bluetooth died on me, and I want to regain the bluetooth connectivity.
The radio only needs to be replaced correct? The radio has the bluetooth receiver right?
When I have the car on and running, I press the call / audio mute button and usually the radio would respond "Ready", but now this doesnt happen anymore when pressing the button. No audio response, just the radio showing the "audio mute"
Just need to know if the radio is the device who has the bluetooth receiver.
Old Oct 14, 2014 | 08:06 PM
slapbetcommissioner's Avatar
The radio doesn't have the bluetooth in it.
The BLUESTAR module is located in the parcel rack under the back window. Perhaps something came loose in there. Does your on star still work?
Old Oct 14, 2014 | 08:21 PM
I havent tried, I will plug the radio back in and give the Onstar a try.
I will look into the bluestar module now.
I will post what I find!
Thanks
Old Oct 14, 2014 | 08:23 PM
Do you know what that bluestart module part number is? I want to find out where it is at
Old Oct 14, 2014 | 08:29 PM
In for results.
Old Oct 14, 2014 | 08:53 PM
Alright,
So I feel sorta dumb, but I plugged the radio back in after having it out for about 3 hours and the bluetooth works again.
I did try the bluetooth before pulling it out so, there was definitely a problem. I still want to know more about the rear module that provides the bluetooth capability as there seems to be a problem that needed a hard reboot in order to resolve the issue.
Thanks again for the info either way!
Old Oct 15, 2014 | 12:07 AM
More then likely unplugging everything reset something.
Bluetooth can be finicky. Sometimes just shutting off the car will fix it.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
