Calling all those with aftermarket decks....
Old May 1, 2007 | 09:23 PM
highrider43's Avatar
Hey all.....Im going to be putting an after market deck in my balt soon and im not sure what to expect when im putting it in as far as how much room is in the back for all my RCA plugs....I have the American international dash kit and it does not come with a "spacer" to bring the deck out....anyone out there using the GMK350 kit or anyone that has done a deck and had to cut i would appreciate any input on how much cutting i will have to do......Thank you all in advance for the advice.
Old May 1, 2007 | 09:49 PM
Xavipheus's Avatar
theres enough room back there
Old May 1, 2007 | 09:50 PM
halfj99's Avatar
i would suggest getting the RCA cables that the plugs have a 90 degree bend in them..mine puch my deck out just slightly
Old May 1, 2007 | 10:18 PM
Raven's Avatar
i cut my back out. to set the deck in.
Old May 1, 2007 | 10:21 PM
twistedpugsley's Avatar
fit fine with no cutting here.....
Old May 1, 2007 | 10:23 PM
Coblt ss super's Avatar
not sure an auto customs place did mine haha
Old May 2, 2007 | 01:06 AM
EmperorJJ1's Avatar
my deck (fosgate RAVDVD1) sticks out an inch or so and the rca outs are on a harness
Old May 2, 2007 | 02:07 AM
senior_brown's Avatar
i did the same thing, it all depends on the deck really, i put in a pioneer navigation and the plastic backing i cut and also removed a metal bracket back there.
Old May 2, 2007 | 02:23 AM
EmperorJJ1's Avatar
any pics of the back area after being cut?
Old May 2, 2007 | 03:21 AM
lol i just had my deck out 2 days ago, the next time will be to put a few more accessories in. so i'll take a pic then if its not too late
Old May 2, 2007 | 03:23 AM
EmperorJJ1's Avatar
nah thats cool... i just have a few ideas but it will require some major cutting
Old May 2, 2007 | 07:49 AM
Bandit2941's Avatar
I had to notch the plastic on each side behind the radio for my Alpine (one side for RCAs, other for antenna). One of those hot knifes works perfect for it (the hot knife is an attachment for my butane powered portable soldering iron).
Old May 2, 2007 | 08:51 AM
mesatrin's Avatar
Had to do the same thing. Cut the plastic X shaped piece out and the metal bracket behind that. Be careful if you cut these out the tunnle for your heater/AC are right back there and you do not want to put a hole in that.
I have an LS but I don't think it should be any different in an SS.
Old May 2, 2007 | 08:50 PM
thanks guys and girls....
Well looks like most people have had different experiences with the headunit installs so thanks a million for all the responses so far......only 2 weeks to go and the black and silver balt gets its black and silver JL Audio makeover
Old May 4, 2007 | 08:51 AM
EmperorJJ1's Avatar
do you have any pics of that by chance?
Old May 5, 2007 | 12:55 AM
Bandit2941's Avatar
No I don't. Next time I have the dash apart I'll take some (will prob be awhile). It's pretty self explanatory once you get back there. I didn't have to cut into the metal at all.
Old May 5, 2007 | 01:30 PM
EmperorJJ1's Avatar
ya ive looked back there quite a few times... but im going to need some serious cutting for something i have in mind
Old May 5, 2007 | 02:38 PM
sp00n's Avatar
Yeah I had to cut the plastic behind my pioneer head-unit so the RCA's would fit nicely. My deck sits flush. People say they have removed the metal bracket behind there. Did you cut it out or did you actually remove it? (unscrew or unclip etc...) I was thinking with the new additions i'm making i'm going to need to wire some more RCA's so that metal bracket may be an issue.
Once I install my new stuff i'll take photos of the cutting i did to remove the plastic backing for everyone to see.
-sk
Old Mar 12, 2008 | 12:03 AM
mikey13's Avatar
I joined this forum for this exact reason. I couldn't get my deck to fit. I thought about cutting up the back. Instead I just flipped the install kit upside down. Just had to cut a couple of plastic tabs on the kit and screwed it back in upside down. The deck now sits under that metal bracket. Got the idea from installs i've down in ford trucks. The installation kit would always have the pocket over the deck.
Old Mar 12, 2008 | 12:18 AM
jekqmb's Avatar
My Pioneer sits flush......It looks great, but then again i wasnt the one who installed it, an Audio shop did.
Old Mar 12, 2008 | 12:50 AM
Spun's Avatar
I joined this forum for this exact reason. I couldn't get my deck to fit. I thought about cutting up the back. Instead I just flipped the install kit upside down. Just had to cut a couple of plastic tabs on the kit and screwed it back in upside down. The deck now sits under that metal bracket. Got the idea from installs i've down in ford trucks. The installation kit would always have the pocket over the deck.[
Something like that
My First Deck was a Panasonic, the RCA's were in a dongle, so it fit in fine. The one you see here is a JVC, and the RCA's plug right in the HU itself, so I fliped it around to avoid the bracket.
I found even fliped around the RCA's still pushed up against the bracket bad enough to cause feedback so I hacked it out, no more feed back once it was gone
My newest HU is a JVC 7" screen, But I could not find a double din kit for it, I was never known for my patients so i took a Dremel and a file to a single din kit and made it fit, I'm still waiting on the double din I ordered, I should have just gotten one from ebay. Here how it turn ouit, its pretty gheto, but it fits for now
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
agentirons
Oct 16, 2015 02:11 AM
patooyee
Oct 15, 2015 05:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
metroplex
Sep 27, 2015 07:48 AM
