Connecting new h/u...
So my new h/u is installed and works, but the power wire is connected to the headlights power wire in the fuse box on the side. I need to find another wire (like windsheild wipers / sunroof) where i can tap into to connect the power wire from my new deck so I can always have power, not only at night LoL!! Does anyone know which cable is it? Which color? Thanks!!!!
how do you connect a wire onto a fuse? I didn't think you could... Well under the fuse panel on the side of the radio, theres the wires. I thought you can only connect it to an existing wire which is why I asked for the color. Explain the fuse tap process please
Originally Posted by vic_romano
use one of these, attach it to the positive?(right) side of the fuse for the sun roof and connect the other end to your red power wire coming from the stereo.
Firesting, the tab that sticks out of the fuse with the fuse tap is perfect for an insulated female spade terminal to connect to. This way everything is insulated and securely connected.
Is there a picture of how to connect it, since im a newb to connecting these things, and i dont wanna burn anything... if possible a pic on how to connect it! And can i find this at like Canadian Tire? I think so...
