Custom Sub Boxes.
Old May 16, 2010 | 12:12 AM
IdreamofYenko's Avatar
Custom Sub Boxes.
Ok so I've been trying to figure this out for quite a while. I want to have better sounding subs in my trunk but I wanna keep it light and out of the way. To do this I have come to the conclusion that I'm going to have to build custom boxes. I want to pull the stock box, replace it with something that hides a little more and then have a matching box on the opposite side. I will use a pair of Shallow mount 10" subs. My question is has anyone built a box to go in place of the stock box. What dimensions should I be looking for to match the resonance of the sub? Any advice would be helpful.
Im thinking something along these lines for subs.
http://cgi.ebay.com/PIONEER-TS-SW251...item51904cb8b0
http://cgi.ebay.com/ROCKFORD-FOSGATE...ht_3856wt_1139
Last edited by IdreamofYenko; May 16, 2010 at 12:12 AM. Reason: Automerged Doublepost
Old May 16, 2010 | 12:19 AM
EmperorJJ1's Avatar
you want it louder?
Old May 16, 2010 | 09:01 AM
Yeah I want it to be a little bit louder on the low end but more than anything I want the quality of the sound to be better. I notice that on songs with a lot of bass, if you try to turn it up to jam, the bass begins to break up and it starts to sound bad.
Synopsis: I want it slightly louder on the low end. I want better sound quality. I want to keep it low pro and out of the way.
bump?
Last edited by IdreamofYenko; May 16, 2010 at 09:01 AM. Reason: Automerged Doublepost
Old May 16, 2010 | 01:10 PM
chitala383's Avatar
i had that pioneer sub but in 12" and now i have that rockford sub also in 12. the rockford is by faaaaar superior
Old May 16, 2010 | 05:28 PM
Good to know thanks now I just need some advice on the box issue.
Old May 16, 2010 | 05:36 PM
CudaJoe's Avatar
http://www.350z-tech.com/zwiki/Tutor..._Fiberglassing
There ya go, follow the steps thaat guy used in his 350z and just apply them to your cobalt. Cant wait to see what you come up with!
Old May 16, 2010 | 08:19 PM
EmperorJJ1's Avatar
ya do that. have fun thou
2 shallow subs on a real amp in small ass boxes will get u louder but its not going to be deeper. maybe a little but not much
Old May 16, 2010 | 11:33 PM
Good link that's definitely a way to go about it. I guess fiberglass would be the best way to go but damn that's a whole lot of work and I don't really have any fiberglass experience with it. I wanna keep it kinda stock looking if at all possible.
I want to TRY to stick with shallows to save space but I'd prefer sound quality so if I have to sacrifice space for sound I will. I don't normally keep much in my trunk anyway, but I want to be able to if I ever need to ya know?
Old May 17, 2010 | 12:53 AM
EmperorJJ1's Avatar
oh and remember there isnt anything really "wrong" with the sound quality of the stock sub. the reason it sounds like **** when u have it cranked is because it can no longer get that loud
if u really want to bang. find a DD dealer in memphis that builds custom boxes. tell them to build u a custom ported box for a 1500 8" and it wont take up more space then the 2 10s, it will be cheaper then the 2 10s the only disadvantage is it should be in a normal style square box pointing back. and it will be loud trust me
Old May 19, 2010 | 06:56 PM
ss2.4lvvt's Avatar
whoa! dont do anything that link says.. duct tape is the key.. you cover what you want to mould with duct tape.. any big flat surfaces you put mdf boards... when you fiberglass you glass up to the and onto the boards.. when glass is done it peels right off the duct tape and voula! instant mould.. then add a few more layers.. 3 to 4 is far enough( 7 will be bullet proof if you want it to last forever but who keeps a car forever?)... pull mould out and set mdf rings in place with mdf supports at what angles you want subs to be... cover with fleece... soak fleece with resin and let harden... when hard fiberglass over fleece again 3 or 4 layers... last step fiberglass over edeges to make a sealed box then cover with carpet or body fill and paint..
if you want ideas on how you "could do a box in the corner i just posted the box i made.. and can help you with anything if you wanna pm me.. my thread is at the top now.. "my new box" hope that helps..
ineedacobaltss
Nov 7, 2015 02:25 PM
chefhhr
Oct 26, 2015 10:36 PM
patooyee
Oct 15, 2015 05:11 PM
How to Guide
57
Oct 15, 2015 11:56 AM
